PC Power Problem
My Advent T9103 has for some time been experiencing problems on Start-up after being shut down the previous night. It would sometimes take a long time to Start-up when pressed momentarily and sometimes I would have to depress the Start button for a long time before it would start. As a result of this we decided to leave the PC on permanently. Unfortunately, the PC shut itself down the other day and we have not been able to start it up again since. Have you any advice please?
PC Power Problem - a64116f.jpg08c1cf0.jpgef4690e.jpgI also have a Dell 8400 heat problem . I know the problem ! I own a $1000.00 plus Raytek laser temp gun . I had some problems and started to read about all of the Dell 8400/4400 over heating problems . I out my new heat gun and started to test the temps. on the inside of my Dell 8400 ! Socket 775,Mobo Dell 0J3492,800 Bus,Bios A09.
The non-fan Radeon x300 card was 105-115.3 F after one hour !
The heat sinks over the chipset was the big problem . 107.8-124.6f after just one hour! The P4 cpu was 93-104f .
I am very lucky to have the laser temp gun I have .
The fix . I have all kinds of old fans and hard drive coolers from computers I have trashed over the years . I got new 40mm/10mm fans on the way from the bay . I had to use some old worn out fans 40mm fans to hold me over .I ordered a new video card also . THEY WORKED ! My temps dropped down to 82-85f on the chip set and video card after running the fans
Posted on Feb 02, 2008
    Scholar:
  • 32 Answers
This is almost always a failed power supply unit, probably some burnt out capacitors, that would cause a shortage of current, not giving the motherboard enough energy to propagate the CPU, so the signal to boot never comes. Depending on your level of expertise on soldering and electrical equipment, you can replace a burnt out capacitor without trashing the PSU. Beware though, as you can run a risk of electrocution if not careful in doing so.
Option 2 is replacing the power supply, and judging by the size of its case, it will either be a Micro-ATX or a proprietary form factor, take in your old unit to a computer store so they can find a unit with matching pins and wattage.
Posted on Jan 08, 2008
From what you are describing it looks the system needs its power supply replaced, these you can find at local electronic stores.
Had my c1630n for years and suddenly lately i have had it just turn off on me at different times. There are no errors showing in event viewer each time it does it. Sometimes it runs all day the shuts down...
Check the CPU fan's Heat sink whether it heats up such that you are unable to touch at the time of automatic shut down. If it is so then remove the fan and apply some Heat Sink Compound between the fan and processor, reattach the fan.
Mar 23, 2011 | HP Pavilion a1630n PC Desktop
I have an Advent 4211c notebook - sometimes when I attempt to use the shut down option from the start button, it wont work and I have to resort to using the power button. This problem is intermittent. Any...
sounds like windows is having an issue with stopping a program that is running at the time that u try to shut the computer down like what programs are running when u try the shut down
it can also be caused by a corrupt registry or something as simple as a corrupt driver
Jan 27, 2011 | Advent 4211c Notebook
My Advent netbook keeps asking me to reboot it. How do I do that?
For rebooting your netbook. Click start and then shutdown and then restart. This will reboot your netbook. If it doesn't shuts down press and hold the power key for 5 seconds or more and it will be turned off.
May 23, 2010 | Advent Netbook
Lamp or Power Supply (Ballast)?
Power Supply is the problems.The lamp problems you will not have picture at all.U said have power and picture all day sometimes right?Power supply board have intermitten problems.
Mar 04, 2010 | Panasonic PT-56LCZ70 56" HDTV
Normal shut down on pc, now it will not power up.
if you can figure out what pins your power switch is plugged into you can try and bypass the switch as for the power supply itself i know theres a way to trick it and boot just the power supply but i cant remember what pins on the plug it is try and google the power plug layout it should tell you what pins to connect to boot it
Oct 28, 2009 | ASUS A7N8X-VM Motherboard
I am having problem in starting up my system.once system has shutdown ,it fails to start immediately after pressing the start button.even after 2-3 hrs it does not start on pressing the start button.but...
Sir,
Let me tell you that do not use UPS current on to the computer as the current in UPS is (AC) it would blow whole of the power supply or might effect to your Computer processor. As now you are suggested to get new power supply. hope fully this would work
Aug 30, 2009 | Computers & Internet
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Installed SH-S202 dvd writer some time ago, and since that time have experienced shut down problems on my Dell with XP pro. It never shuts down, but seems to go into Standby mode first. Then, when it...
Check the power settings:
START | Control panel | Power settings
Make sure all settings are Never
Also go to the Advanced tab and remove any Standby entries.
The DVD Writer installation is most likely a coincidence then an actual suspect with the standby issues.
Thanks,
Vincent
Nov 21, 2008 | Computers & Internet
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Window resume loader
Windows Vista doesn't shut down the machine by default when you press the power button. Additionally, if you look at the bottom of the start menu you'll see this:
The button on the left, highlighted here in bronze, does NOT turn the machine off in Windows - it suspends it, which requires power. When the battery runs down, the power goes out and you get this message the next time you start up.
Some laptops also indicate suspend mode by flashing the power light.
Happily, if you click on the little right facing arrow a menu pops up, one of the options of which is "Shut down" and this will bring Windows down properly and fully.
You can also change the function of the power switch (which defaults to suspend, NOT shut down) by going into the power options from Control Panel:
Selecting one of the above options will allow you to set the power button and closing the lid to turn the machine off fully, not suspend it.
May 27, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
