Question about HP Pavilion dv9000z Notebook
My laptop (hp window xp) can't connect to the wireless internet ??? It won't even let me type the password. Everytime when i click on it, it starts connecting. but before the password typing comes, it says the wireless internet may not be there anymore, and try again. But i can connect to other wi-fi. And many people can also use it, but just not me¬
  • 535 Answers
You have problem with router range your laptop has been not get proper signal from the wireless router when got signal you get password screen then after due to signal is week the connection will lost
Posted on Nov 13, 2009
Breaker box went out where wireless router is plugged in and when we turned it back on, the HP notebook pavilion g7 won't connect to wireless. Message says the computer settings don't match t
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Dec 29, 2012 | HP Pavilion G7-1227nr Notebook 4gb Ddr3...
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
May 10, 2012 | Dell Computers & Internet
No wifi toshiba satellite a665d s5178 un able to install a wireless drive and fnf8 doesnt work
Is the wireless switch on that is located on the side or front of the laptop?
Did you ever see any wireless networks to connect to? If so, did yours try to connect? maybe you have the password/network key in wrong. It will never connect if the password is wrong.
May 09, 2012 | Toshiba Satellite A665D-S5178 15.6-Inch...
Cannot get the internet to work
May 08, 2012 | Computers & Internet
HP built-in wireless internet light cannot be
try this...
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 03, 2009 | HP Pavilion dv9000z Notebook
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
Wrt310n adding wireless laptop
If you are using windows xp :
Go to Start>control panel> Network and internet> network connections > right click on wireless network > select 'view available wireless networks' and select your home network and click connect. If it asks for a password i guess u have it or if u dont have then go to Internet Explorerand and type 192.168.1.1 in the address bar, it will ask for a username and a password, type admin as username and the same for password. it will take you to the lynksys page....then select wireless and click wireless security, it will show you the wireless password.......
If u have windows vista :
Click Start > go to 'connect to' > select the wireless network you want to connect to and the rest is the same as windows xp....
Hope this works out
Regards,
Anup
Apr 07, 2009 | Linksys WRT160N Wireless Router
HP Pavilion dv9000z Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
