Question about Samsung ML-2510 Laser Printer
I HAVE A SAMSUNG LASER PRINTER BLACK AND WHITE IT GOES TO SAVE RATHER THAN PRINT WHEN I CLICK PRINT ON THE PROGRAM.SO WHAT IS WRONG WITH MY PROGRAM ? IT'S A ml 2510
    Problem Solver:
  • 10 Answers
You need to click "start" then "printers and faxes" and check to see if your printer is installed. If it is, look to see if there is a little black check mark on it. If it isn't, click once on it and then right click and select "set as default printer". If it is indeed trying to print to file, this will solve your problem.
Posted on Nov 21, 2009
  • 26 Answers
Off the top of my head, it sounds like you've got the "PRINT TO FILE" option/feature enabled. Look in/around File->Page-Setup for the option and un-check it. For an exact location, you have to tell us what "MY PROGRAM" is.
Good Luck!
Under the print setup, Use the "Print Test Page" If that is not working then you will have to see if one of the problems above. On the other hand. The tones might not be inplaced correctly. That is what i have found when moving the printer around to another place or building.
Be sure to switch off the printer to reset the print it self and delete any pages waiting to print. Set the printer as default. Print a test page.
If all else fails. You should return it to be checked, But this printer is so cheap it might be just better to get another one and you will receive a new printer and new toner for about $14 that a Normal Refill toner.
After ever two year you will need to get another Printer anyway as the lazers don't act well after that. But for the Sumsung its a Good Buy Printer.
Good Luck
Posted on Dec 13, 2009
Samsung Xpress M2875FD Laser reset firmware
download from samsung website,may use foll link:
http://www.samsung.com/uk/consumer/it/printer-multifunction/black-white-multifunction-printers/SL-M2875FD/SEE
Feb 12, 2014 | Samsung Xpress M2875FD Laser Multifunction...
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Load specified paper in manual feed?
are you trying to print a pdf file ? if so some times the paper size is not correct for the paper you have in the machine or you have the wrong size selected in the menu settings of the printer.
Apr 16, 2013 | Samsung Ml2955nd Black White Laser Printer
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
It only prints black and white
Somebody must have followed the instructions:
Print Only in Black and White:
• Click Start > Settings > Printers and Faxes.
• Left click on Laser to highlight.
• Click File > Printing Preferences.
• Click on the Color tab.
• Click on the circle by Grayscale to move the bullet to that selection.
• Click Apply and OK.
to switch from "colour" printing to "black".
So, "unclick" the 'Grayscale' setting.
May 09, 2010 | OKI C6100n Laser Printer
Samsung CLX-3175FN printer instructions - How do you set black and white printing to default
3175fn is acolor printer. if you want to set only grey or black only print. you have to go to printers & fax. select the printer right click properties and go to color and set as gery or black only print.
May 07, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
How do you print only in black & white to a dell 5110cn laser printer? the printer is currently out of magenta toner and will not print. do you need a magenta toner cartridge in order to print to this...
go into printer and faxes and and right click on your printer and and go to printer Prefereces you should see either print in black in white or gray scale
this should fix it for you
Good Luck
Happy Computing
Jan 09, 2010 | Dell 5110cn Laser Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
Samsung Printing Trouble
make sure that when you go to print under propertys choose color tab and then color
Apr 07, 2008 | Samsung CLP 300 Laser Printer
Samsung ML-2510 Laser Printer Logo
155 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
