Question about Maytag MER6872BAS Gemini Electric Kitchen Range
MER687BAS WONT HEAT BOTTOM OVEN ONLY BROILS IS IT JUST THE ELEMENT?
I just want to let everyone know I had the same problem with our mer6872bas oven where the upper oven stopped coming up to temperature 2 years after it was purchased. The lower oven stopped coming up to temperature 4 years after purchase. Both broilers worked. I spent a lot of time researching the problem to find out that the relays were soldered to the control board insufficiently. The solder had melted, dripped down onto a heat shield and all conductivity between the relay and control board was lost. This resulted in only 115v being applied to one side of each lower heating element. There are terminals on the backside of the relays that can be used to re-establish the connection. Both of my lower elements work perfectly now.
Posted on Aug 06, 2010
  • 48 Answers
Steps to check element. TURN off breaker that feeds oven. Unistall bottom element in question. With a continuity tester see if element has continuity. If it does not then element is bad, replace it and turn on breaker. If it does you need to call a technician because the next step requires voltage testings that can shock you if done improperly..
Posted on Nov 13, 2009
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Hotpoint electric oven does not bake but broils
Check your oven heat element. It sounds like it is shorted or cracked
Mar 16, 2014 | Hotpoint Ovens
When I press to heat oven the broiler comes on, instead
what are we diagnosing here , Dale?
who makes this 'oven' that broils ?
Is this a new oven ?
Ever use this oven before ?
What model number is your oven?
Please give us something to work with here , Dale.
Apr 08, 2013 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
My whirlpool electric oven broils but doesnt bake. model rf385pcwn1
Hi
The possibilities are a bad Bake element, a broken wire to the Bake element or a bad control board.
You have to remove the Bake element or to pull the range off the wall to perform the troubleshooting and find out which part is bad.
You have to inspect the wires, then remove the wires from the Bake element and check the element for continuity.
If there is nothing wrong then you have to check for 120VAC between each wire and ground and for 240VAC between the wires while the control calls for Bake. If there is no proper voltage then the control board has to be replaced.
However To remove old element, there are 2 bolts/screws on the back of the oven, attached to the element. There will be a silver bar holding the screws/bolts to the back of the oven.
Remove these screws/bolts with either a screwdriver or pliers by turning to the left.
After unscrewing the bolts, pull element out. It will have the electrical wires attached to it with a clamp on each side. Pull wire clamps up to remove the element.
Remove new element from box. Slide new element clamps up into the wires coming out from the back of your oven. (There will be "legs" to hold the element up from the bottom of the oven. These go on the bottom for support of the element).
Tighten existing screws/bolts onto oven through the holes in silver bracket. Do not tighten too much, just make sure is secured.
Turn electricity breaker on and plug oven into outlet. Turn on to 350 and see if it heats up.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 19, 2010 | Ovens
Oven feature does not work. unit broils fine.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 06, 2010 | GE Profile JS968SKSS Stainless Steel...
Oven does not heat up when we try to bake.
no element ... there is an ignitor, u might need service prob worth repariing, if not turn if gas unplug and remove inside cover on bottom and get acess to ignitor,, u can find one locally or online at sears or repairclinic.com u dont have to get the kithenaid part it is only more expensive it could be a 12400035 or an sgr403 depending if its a round or square ignitor those are less expensive... hope this helps let me know
Apr 08, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
Oven bottom wont heat
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Maytag MER6872BAS Gemini Electric Kitchen Range Logo
297 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
