Question about NetGear WPN111 RangeMax Wireless USB 2.0 Adapter: WPN111NA (NTUSNGWPN111)
WIRELESS NETWORK ADAPTOR HAS SIGNAL BUT NO INTERNET
I am having problems with my netgear wireless adapter. I'm geting _____ . _____ . _____ . ______ on my netgear smart wizard thing it's recieving a signal but i can't access internet.
hope someone can help !
What do I need to do
Posted on Nov 14, 2009
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Mar 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Network adaptor question
you can buy a wireless bridge which will give wireless capabilties. Netgear makes one and others.
but you can hook up with a wiireless adaptor unless you have a wireless rounter or a bridge
Jun 17, 2009 | Microsoft Wireless Network Adapter Xbox...
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
NETGEAR WG311v3 Wireless PCI adapter STUCK on scanning.
Hi
What you to do first verify that the device is installed properly for that ---
Go to Device manager-- click on Network adaptors -verify the your wireless adaptor is listed there without any yellow or red mark .If you see a yellow mark then you need to install and reinstall the adaptor
Second , You might see an icon for netgear adpaptor in right lower corner under taskbar and you need to Right Click on it , it will show you several options just look for use window to manage wifi or xp wifi client , like that .. sect that option ..
after that it will display a message wireless network detected , click on the messege , you will see your network . select and connect
Mar 29, 2009 | Computers & Internet
Netgear Wireless USB 2.0 adaptor cannot find a signal
Before doing that, make sure your wi-fi is turned on in your router. If the adapter is not seeing a signal, it may well be that your router is not broadcasting one. If you have another computer with wi-fi (like a notebook), or know someone who does, you can always use it (or theirs) to see if they can "see" the router via wi-fi, which will tell you if the problem is router or adapter.
Cheers
Nov 10, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Router
there is no other devices signal affect to your wireless .do one thing reinstall ur wireless adpator
May 19, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Compaq evo n610c
You need a PCMCIA Wireless adaptor, (this model you are getting has two slots that it will fit in) - and you must make sure you have a wireless router in your house to broadcast a wireless signal for it to recieve.
Mar 28, 2008 | Compaq Evo N610C Notebook
Wireless Network Dropping Out- NetGear WPN824 V.2 & Atheros AR5006EXS Wireless Network Adapter
Fergus,
Steps to troubleshoot are as follows.
1. check the physical connections. Go to a broadband testing site to see if you are connecting correctly b/c i am assuming you are wanting to connect to the internet. if not see next step. A common problem with internet connections is the timeout setttings on netgear you should set it to 0 for indefinite.
2. if your problem is related to just the connection between your pc and your router then you should just plug a lan cable in first to see if you can connect to the router without dropouts. This will help you to determine if the problem is with the router.
3. If it is the router then you need to double check your router configurations. Common problems are firewall rules, port forwarding settings etc etc.
4. if it is not the router then double check that the pc and the network card is working properly. If it is then make sure the the wireless adapter support the protocl eg. wep, wpa, wpatsk etc..make sure they are the same and that you should be setting the network key.
5. one final check is you need to turn off some of the rangemax functionality on the router b/c your wireless adaptor probably doesnt support it. try unsecure connections for a while to see if it works then start adding functionality to determine which one is the culprit.
I hope this help.
smeags.
Dec 31, 2007 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
360 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
