Question about Samsung HL-S5087W DLP TV
No sound or video from my hl-s5087w samsung tv
I have no sound or video from my hl s5087w samsung. It has a brand new color wheel and lamp. When I turn on the tv the lamp button flashes green for about a minute and then goes out, so none of the lights are lit. However, after a short while the tv shuts off into standby mode. I hear no sound and see no video.
Could it be the light tunnel?
  • 1 more comment
  • info58029 Nov 13, 2009
    Hi. Yes, that cover was put on properly. It seems I am not getting any source audio or video. Could that switch itself go bad? How could I test if it is the switch.
    Basically that switch can be pushed up or down. I've tried holding it both ways to see if that fixes it and nothing. Is there a way to override that switch just to test it? Thanks.
    I forgot to mention that the lamp is firing up night and bright. It's just not shining through to the screen and the system shuts off. So the lamp is working. Could it be the light tunnel?
    However, wouldn't I be able to at least get sound? I don't get anything at all. Thanks for your continued help with this by the way! :)
    Connections are all there and fans (2) seem to be spinning. This problem was happening before the color wheel was replaced. Technician said color wheel was the problem, but obviously it is not. I replaced the color wheel myself following precise instructions (I'm not technically challenged.) :)
    I was hoping that replacing the color wheel would fix it, but nothing. Still no sound or video showing up through to the screen. Could be an issue with the light tunnel? Would that prevent it from turning on? I do know that prior to it dying, the tv was having the "light tunnel shadow" on the right hand side of the screen.
  • 10,594 Answers
OK, make sure lamp cover is fixed properly after lamp replacement.
There is safety switch under lamp cover that need to be pressed by lamp cover, that switch sends signal to system control chip, if that signal is missing, TV wont power up and shuts down because of protection activation.
Let me know further query, if any.
Thanks.
Posted on Nov 13, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Nov 13, 2009
    Lamp cover is in place and switch is working, ballast power supply sounds defective that provide high voltage to lamp to fire up.
    I do not recommend to test/ check ballast power supply as its qualified tv tech job, please make sure that ballast supply connectors are hooked/ plugged properly.
    Thanks.
    Oh great, lamp fires up and gives light, ballast supply is OK and working.
    Please check fans are running in TV? if any fan is not spinning, check its connector plugged in circuit board. All fans are monitored by system control and if any fan gives error, TV will shut down.
    Please recheck all connectors that were removed/ unplugged during replacement of color wheel.
    Thanks.
    Any problem with Light Tunnel can affect picture quality but protection activation is some thing else that prevent TV to turn it on.
    Color wheel spin is also monitored so jammed / broken color wheel can shut down TV.
    Do you have service manual copy in hand to troubleshoot as manual has related info.
    You can download service manual/ schematics from HERE for small fee, if required.
Samsung HL - S5087W. TV originally would not come on. I put a new lamp in and picture will start out dark, then will lighten up. What part is still in need of replacing? cooling fan? color wheel?
Shay, where did you get your lamp from? If you bought a sub-par generic lamp, then the result will be exactly what you described. Generic lamps can be found abundantly on Amazon or eBay type marketplaces... i would stay away from shopping there. I recommend a site called Discount-Merchant or SamsungParts... D-M seems to be the cheaper one for original Philips brand replacement lamps.
Make sure you are buying a Philips and not a generic or knockoff Philips.
Another good resource for troubleshooting your TV is the FixYourDLP forums... You can get lots of help there as well!
Jan 14, 2014 | Samsung HL-S5087W DLP TV
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
My dlp tv (model number-hl-s5087w)is making a humming noise
Bad Color Wheel.
Samsung Parts 1-800-627-4368
Mats 1-800-628-1118
Oct 14, 2010 | Samsung HL-S5087W DLP TV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
HL-S5087W has become dim in picture
if the colors look good and its just dim its the lamp. usually the lamp will show signs of being bad by looking at the base of the shaft in the middle if its discolored or warped the lamp is bad
Jan 30, 2010 | Samsung HL-S5087W DLP TV
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Hello. I have have an HLS5087W DLP tv and I have no sound or video. I just replaced the lamp and the color wheel so they are brand new. Any ideas what could cause the problem? I don't get any video - even...
Do you see any light blinking at TV front?
What was previous symptoms that you decided to replace lamp and color wheel?
Do you have service manual/ schematics in hand?
Let me know above to diagnose problem.
Thanks.
Nov 13, 2009 | Samsung HL-S5087W DLP TV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP TV Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
