Question about Creative Labs Computers & Internet
When I try to boot my PC I see the Point of View info in the top left hand corner of the screen but everything else is garbled. The Windows XP info appears but the system fails to launch and switches off leaving the screen showing ''no signal'' Is it the card or the BIOS that's a problem?
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 13, 2009
Testimonial: "Brilliant!"
Dell latitue D610 stuck on black screen with a blinking cursore.. help?
First, try and boot into safe mode by powering off your computer then powering it back on and tapping the f8 key, after that you should see safe mode and other options below it, click the first option which is safe mode, then go into your start menu and go to your system restore which in Windows 7 and Vista is located in accessories and then system tools, then choose a restore point earlier than the date you are on. This is a temporary fix and you will need to get a virus removal done asap. Hope this helps.
Live Technical Support
My Youtube Channel
Mar 24, 2013 | Dell Latitude D610 Notebook
I have a sony PCG-6N2L..when I turn on the computer, the logo screen comes up then the windows xp sreen...it doesn't ever bring up my sign on screen it keeps repeating the logo screen and the windows xp...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Apr 11, 2011 | Sony VAIO GRZ660 Notebook
OK all i did was turn my computer of by the switch because it was getting real slow and i couldn't do much because of the speed it was going so when i turned it back on it came up with the hp start up with...
You will require a start up/recovery/system disc as the boot sector has been damaged.
If you can get it to boot with a start up disc, run Scandisk to try and recover the sectors. If that doesn't work, reinstall Windows, bearing in mind most XP drivers are now obsolete.
Jan 23, 2011 | HP Computers & Internet
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Just installed windows 7 with an external cd/dvd and now it will only boot with the cd/dvd attached. otherwise a black screen appears with the cursor in the top left corner.
when it boots to a flashing cursor in the top left corner and everything else it working, this means that it is NOT finding the operating system on the hard drive, many times due to boot sector issues.
Make sure you set your hard drive to main or first startup device.
Jun 05, 2010 | ASUS Eee PC 900 PC Notebook
Can't get the windows screen to come up on the computer only a blank screen with the cursor blinking in the top right hand corner. acer aspire one notebook
Change the boot sequence in the bios and let the windows be in the top drive, save changes and exit let it boot from the disk and follow the steps below
Do a repair of your XP installation.
•Boot from the XP CD
•At the Setup screen - Press enter (NOT R for repair)
•PgDn and press F8 for the Licensing screen
•Select the XP installed location and press R to repair
•Setup will copy install files and then reboot the machine DON'T REBOOT FROM THE CD. Let it boot from the hard drive.
•When it is done the process, remove the CD and reboot normally.
This applies to all os like win xp vista and win7
Feb 02, 2010 | Acer Aspire One PC Notebook
My windows xp stops booting
Is the monitor blank or is there a blinking cursor in the top left hand corner.
Feb 01, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
544 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
