Question about Dell XPS 420 DESKTOP - Intel?® CoreTM2 Q6600 Quad-Core , CD/DVD burner
Dell latitude d600 cannot change appearance setting to anything but 640 by 480. it did not used to be this way. I tried all the troubleshooting on dell website. tried to restart in safe mode and change settings.
  • 1 more comment
  • mwalstead Nov 13, 2009
    tried using dell wizrd to view configuration, cannot find any video card info
    in other words, i do not know what is the "correct" driver to install. i don't need anything fancy. it is just a work pc, i just don't need to see the pointer from 2 miles away
  • 468 Answers
Did you install appropriate graphic drivers
Posted on Nov 13, 2009
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
D600 monitor is blank after I unplugged power cord
Your battery got fried Try replace with a new battery.
Jul 28, 2010 | Dell Latitude D600 Notebook
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
May 20, 2010 | Dell Latitude D600 Notebook
How do i restore my dell latitude c600 to its factory settings
The Dell Latitude C600 is an older Dell laptop computer. This particular model came with Windows XP pre-installed on it. If you are experiencing problems with your computer, or you want a fresh start with your Dell, you can restore the laptop to factory settings. This process removes all of the data saved on your computer and resets all of the settings back to the way they were when you first purchased the computer.
Instructions:
Step 1
Turn off your computer if it is currently on.
Step 2
Turn on your computer. When the Dell splash screen appears, hold down "CTRL" and "F11" on your keyboard. Release both keys at the same time.
Step 3
Click "Restore" in the "Dell PC Restore by Symantec" window. Click "Confirm" when you are warned that all data will be lost.
Step 4
Allow the system to restore and wait for the message that says "The system recovery process was successful." This can take about 8 to 10 minutes.
Step 5
Click the "Finish" button and your Dell Latitude D600 is restored to factory settings.
May 10, 2010 | Dell Latitude D600 Notebook
Restore dell d600 to factory settings
Resetting a Dell Latitude to the factory settings allows the user to restore the Dell Latitude to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Latitude laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Latitude laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Latitude reset process...
This process will erase all your previous changes that have been made to the Dell Latitude laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance
for all models of Dell laptops(Vostro, Latitude,Inspiron...etc..) at http://www.vtechsquad.com/dell-support/
Mar 25, 2010 | Dell Latitude D600 Notebook
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 wont turn on
test power supply- test ram- have cpu tested- test connection from front button to motherboard
My dell latitude d600 onboard bluethoot just doesn't work, don't even know how to start it up.
go to control panel, classic view, bluetooth. self explanitary from there, unless ur dell is like mine and doesnt have the hardware installed!! so youve just got a light that wont do anything
Jun 01, 2009 | Dell Latitude D600 Notebook
Can I connect my dell latitude d360 laptop to my tv?
When you connect the VGA cable to the TV you will need to hit the FN button + F5 on your keyboard, that will change the dispalys from internal to external. if you hit FN+F5 again you can have both the laptop and the TV screen on.
May 31, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 won't go past the Dell startup screen
Tap the f7 or f8 key, when you turn it on, it should go into safe mode, Go into start programs, accesories, tools, and restore, select restore, select a date closest to today and let it go through the restore pocess, if it suceeds and starts up, rub a good virus program right away, it sounds like you picked up a virus or trojen, just be patient and it shoul be ok, if it won't go into safe mode, let me know, that will require more work. And before you do anything, unplug, remove the battery for a few minutes and replace, try it and if it still won't run, do the above, thanks ,GYM
Dec 19, 2008 | Dell Latitude D600 Notebook
Dell XPS 420 DESKTOP - Intel?® CoreTM2 Q6600 Quad-Core , CD/DVD burner Logo
63 people viewed this question
Alun Cox
