Question about Acer Aspire 4315 Notebook
I do not have problem with computer I was wondering the max of memory I can have on this model.
  • 468 Answers
4Gb
Posted on Nov 13, 2009
Testimonial: "very helpful "
  • Acer Master
  • 4,806 Answers
The maximum memory that the laptop can support is 2GB.
There are 2 DIMM (memory) slots, each will support 1GB SODIMM laptop memory which runs at 533 MHz.
Regards.
  • Lee Hodgson
    Lee Hodgson Nov 13, 2009
    Here is the quick spec sheet for the laptop >>>>>>>>>
    http://static.tigerdirect.com/pdf/Acer_A...
Hi, wondering if I should upgrade my sony vio pcv-rg22z and what the max upgrade on memory etc is?
Hi. I hope this information helps you out.
The rz22g model has a max memory amout of 1 gb, using two 512 mb slots.
So you can get 2 512mb pc2700 memory modules for it, as this would max out the memory just make sure that the memory is of compatible type and build. You can't just go get cheap pc2700 ram and put it in, it might not work at all.
As far as other upgrades, it has an ide interface, so probably won't be able to find a drive bigger than 500gb, but that's a pretty big drive right there!
For processors, It appears that a 3.0 ghz pentium4 w/ht is the best you can get to fit, that's if you can afford one. They can be a pricy investment, and in the long run, you could almost buy a new computer that has dual or quad core performance for about the same price.
You can get any brand of pci video card, i recommend nvidia, as it has better performance than an ATI card. The newer the better as far as models go, just get the one with the most memory for what you can afford. Most good video cards can cost about $100, but if you go to tigerdirect, they have a Galaxy nvidia gtx430 on sale right now. It has a giabyte of ram on the video card, as well as having vga, dvi, and hdmi jacks, so you can hook it up to just about anything nowadays.
I hope this has helped make some decisions, and hope that it goes well for you.
Jan 26, 2011 | Sony VAIO Digital Studio PCV-RZ22G PC...
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    I'm looking to upgrade the RAM in my father-in-law's computer (Compaq Presario SR1500NX desktop). All the "see what ram you need" searches on various websites that sell memory indicate PC2700 is...
    This is the memory specs for the SR1500.
    Presario SR1500NX Memory Specifications Standard Memory 256 MB (removable) Maximum Memory 2 GB Memory Expansion 2 sockets Memory Comments PC2700 DDR SDRAM DIMMs. CPU Type 2.0GHz AMD Sempron 3000+ Model Comments 333MHz FSB, VIA KM400A Chipset.
    The PC2700 refers to the RAM speed, so you can use PC3200 which is faster RAM than PC2700, the PC3200 RAM should be more expensive not cheaper unless this supplier has stock he needs to unload.
    You will not get any speed performance with the PC3200 RAM because the motherboard cannot make use of this faster RAM.
    Dec 03, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
    I have an older computer that i just had rebooted to clean out an since then it has been freezing up on the internet was wondering if maybe a driver didnt get installed properly or something but i feel...
    are you using IE7 or IE8 (this freezes a lot)... try Opera or Firefox... also try to restore system to an earlier date even though you cleaned it up some.....also find out if your model PC is up to its max in memory (ram) maybe you can purchase and add more
    Nov 13, 2010 | Computers & Internet
    I have a x58c series alptop and was wondering if this memory is ok to add to my latop which has 1024 mb of memory. ...
    Any notebook DDR2 ram will be fine. Your laptop has a max of 2gb per slot and a total of 2 slots. have a look here for more info :
    http://www.crucial.com/store/listparts.aspx?model=X58C
    //halfs
    Sep 01, 2010 | ASUS Computers & Internet
    I bought an Acer AO532h-2964 netbook, and I'm wondering: can I upgrade the RAM from 1 GB to 2 GB, and if so, which memory chip should I buy?
    yes you can, your netbook can have a max of 2gb ram and a max module size of 2gb.
    So you have 1gb pc 5300(ddr667) installed, and you can buy 1 more 1gb module, laptops use sodim.
    Aria.com has a 1gb stick for £25
    http://www.aria.co.uk/Products/Components/Memory+-+Laptop/DDR2+667MHz+PC5300/
    you could also try play.com / amazon / ebay
    Jul 10, 2010 | Acer Computers & Internet
    What is the maximum memory for this computer?
    This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
    Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
    Upgrade memory
    ur computer has an expandable memory Max of 128 MB> anything more than that will be too powerful for ur computer's motherboard> upgrading the memory means u need a new motherboard and if possible a new processor too
    Oct 09, 2009 | Microsoft Windows XP Professional
    Acer Travelmate 529atxv states max memory as 512mb
    512mb is the max memory amount this computer will accept.
    Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
    Mar 07, 2009 | Acer TravelMate 529ATX Notebook
    I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
    Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
    In short.... yeah, 512k is the max.
    Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
    Jan 24, 2009 | Toshiba 2405-S221 Notebook
    Acer Aspire 4315 Notebook Logo
    55 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
