Question about Nintendo NES Console
Nes how do you change the 72pin conecter
  • 37 Answers
Weee... I miss the old days. I am assuming that you have a replacement. And make sure that your power is not plugged.
What you need is a standard size Phillips screwdriver. There are 4 screws at the bottom of the system (Take them out).
Now on the inside, you have to mess with the screws along the board. You won't have to mess with the ones attached to the controller ports, cause it may have long cords like mine did.
There is also a grounding shield that you have to take off the top of the connector you are talking about.
Once all screws are off there are 2 additional ones holding the connector down (If I remember right, they are shorter then all the other screws).
Carefully lift the board itself from the rear of the system and pull the connector out. That should be about it.
Posted on Jan 08, 2008
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
How to conect super nintendo to HD tv ?
put the composite/ yellow into the yellow white into the white and red into the red you can find one of these with any gc or n64, or use the coaxial that was for nes ,
those are your only options back then ,
but expect green lines , as mine does that on any hd tv
Jan 17, 2012 | Nintendo Super NES Console
.i want to change my
make sure ram module its securely seated also this ram might not be compatable with your computer try to keep the same type of ram you already have is it ddr2 or ddr3, sdim,sim 30 pin,sim 72pin ,or dimm
hope this helps
Sep 02, 2011 | Intel D845GLLY Motherboard
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
When I turn on the Snes just appears a black screen, i check the RF conection and it´s ok, right channel 3 i clean where you insert the games with alchol it doesn´t work
Well you could try cleanining the gamepacks with qutips and rubbing alcohal.
But the bad scenario is that the super nintendo console is on its way out.
Dec 23, 2010 | Nintendo Super NES Console
My NES works great but there is a constant buzzing sound in the background. I cleaned the 72 pin connecter and checked he aV conections, But it still does it.
Well maybe the tv is causing this problem like the speakers on the tv are messed up not the console its self then. The console is fine. Its the tv then.
Oct 31, 2010 | Nintendo NES Console
My N.E.S. is flashing on and off even after I
check for bad capacitors, if they are leaking or slightly bulged at the top they'll need changing. good luck
Jan 11, 2010 | Nintendo NES Console
Why do I have vertical white lines when I put any game into the NES system? Games will play but lines are annoying!
thats cause your connector is going bad probably. to verify this, instead of using the RF connector, use the a/v cables and if you get white lines either way then you know the connector inside of the NES needs to be changed.
Jan 05, 2010 | Nintendo NES Console
Have buzzing in super nintendo, replaced rf switch and still have it, any ideas?
hey i would try another rf switch cause they really mass pruduce those things so the wiring and sodering is slopy and if that dont work it migh be the nintendo it's self also try to use a rca cable the one with the red yellow white conecters they give you much better sound qaulity.
Nov 10, 2009 | Nintendo Super NES Console
TURNS OFF
I had the same problem a little while ago. If you are using a third party power source, that is probably the problem.
Apr 04, 2008 | Nintendo NES Console
Nintendo NES Console Logo
69 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
