Question about Panasonic KX-FL511 Plain Paper Laser Fax
MY FAX NOT RECEIVE FAXES. WE HAVEN´T A USER´S MANUAL. SAVE THE FAXES IN THE MENMORY AND WE DON´T KNOW HOW CONTINUE WITH THESE
  • 31 Answers
SOURCE: Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Posted on Mar 27, 2008
leroyal
  • 2120 Answers
SOURCE: cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Posted on Mar 13, 2009
rscheutz
  • 54 Answers
SOURCE: User manual for Panasonic KX-FP81C Plain paper fax
The manual can be downloaded here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FP81
Posted on Mar 25, 2009
FixinFax
  • 3085 Answers
SOURCE: Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Posted on Jun 06, 2009
FixinFax
  • 3085 Answers
SOURCE: Fax machine malfunction
press the monitor key and listen for a dial tone.
Pull open the doc feeder
turn the machine off
hold down the pointed switch by the small glass while turning the machine back on
scroll down to SHIPMENT SET
press set
press 2
wait for the machine to reboot
Posted on Feb 23, 2010
Require user manual for panasonic fax model KX FT 77
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Jan 06, 2011 | Office Equipment & Supplies
press set
press 2
Feb 22, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
I am unable to receive faxes, although I am able to send them. How do I correct this?
More then likley you just have not set the printer to receive faxes. If you have the User's Guide the information is contained under the fax chapter.
If you do not have the manual, please let me know.
Don
Oct 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Hp officejet 5510 fax issues
Have you run through the setup procedure detailed in the User Manual? Unfortunately it is far too large to post here. Can you receive faxes OK? If you don’t know just dial your fax number from any phone and see if it answers and you can hear fax garbage noise down the phone. If so then that is a positive sign. If you get stuck then drop me an email to kw7157@yahoo.co.uk and I can email you a full check and test procedure for this model.
Jul 16, 2009 | HP Officejet 5510 All-In-One Thermal...
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to hookup afax machine?
You can download a copy of the manual at
http://www.devicemanuals.com/guidedownload/Brother-FAX-575-Thermal-Transfer-FAX-Machine-User-Manual-T0RFMk1qVT.html
Jul 21, 2008 | Brother FAX-575 Plain Paper Thermal
I have my husband's Panafax UF 895 fax which I am using since my other fax broke. We set it up, but he can't find the manual -- I can fax out and copy, but can't receive faxes. On the display it says...
Your machine is set to Manual Receive.
You need to change Function 17 to 2.
Go to Fax Parameters on the below link to help guide you through programming the fax parameters.
Basically, you hit FUNCTION, then #7, Press #4 and Set,Enter 17, hit Set, enter 2, Set. After you are done, then press STOP, and your machine should be set to AUTO RECEIVE.
Here is a link for the user manual:
http://www.best4systems.co.uk/_design/best4systems/_pdf/Faxes/Panasonic/Panasonic_UF885_UF895_UG.pdf
You should probably save a copy of the manual on your computer incase the link is lost or shut down in the future.
I hope this helped.
If you have more questions, please repost again and remember to leave a rating if I have helped you.
Good luck.
Mac =)
May 02, 2008 | Office Equipment & Supplies
CANNOT RECEIVE A FAX
Slim1234,
          A multitude of problems might cause receive problems, and the User's Guide has no "receive Problems" section under troubleshooting - so here goes:
        If I had to guess right off the bat, your problem is probably
that the FAX is in "FAX Storage" mode, and is out of memory.
In this mode, it will print FAXes until it runs out of memory.
See problem "g" below.
   a. Voice mail active on the line - if voice mail and FAX-2820 are
       set to answer the line on the same number of rings, there's
       no way to know which will answer first.
   b. Voice mail active on line - if voice mail is set to answer in
       fewer rings than the FAX, then the FAX will always lose
       (but you'll have no problems Xmitting).
   c. Call Waiting active on the line - the call waiting "boop" will
       kill incoming FAXes (and outgoing FAXes too, but your
       personnel will retry the outging ones until they succeed
       and you may only hear complaints about incoming FAXes).
   d. Your FAX-2820 is set to "Manual" or "External TAD" mode.
       Reset it to "FAX only" or "FAX/Tel" mode (depending on
       your office use of the FAX telephone line).
       How to do this: Menu/Set,0,1 <up/down to select mode>
                              press Menu/Set.
   NOTE: your LCD display tells you your receive mode:
       Mine says "Sleep 22:08 Fax", telling me I'm in "FAX only"
       mode, and its 10:08 PM.
   e. You've set the FAX to RING DELAY - if so, the FAX
       must win. Setting ring delay to 00 tells the FAX to answer
       the line silently (an advantage for a busy MD's office).
       How to change this: Menu/Set,2,1,1
       Ref: FAX-2820 User's Guide p.4-2
   f. You dont have a shared (FAX/human) line set to
     "Easy Receive"; if someone answers the call and
      Easy Receive is off, then they need to press START on
      the fax machine front panel or dial *51 and hang up.
      How to change it: Menu/Set,2,1,3
      REF: Fax-2820 User's Guide p. 4-2
  g. You may be set up for "FAX storage."  In this mode, received
      FAXes will be stored (and printed) until you run out of
      memory (quickly done on a Brother FAX-2820), then you
      get nada (but sending FAXes still works).
      How to reset this: Menu/Set,2,5,1 <up/down>
      REF: Fax-2820 User's Guide p.6-2
  h. You may have set up FAX forwarding.  In this mode, sending
      FAXes will work fine, but all incoming FAXes willl be sent
      to another telephone number.
      How to turn it off: Menu/Set,2,5,1 <up/down>
      If this laundry list of (sending OK, Receiving dead) scenarios
 doesn't resolve the problem, email your FAX number to me
and we'll do some cross-country FAX debugging.
                                  Dave in tech support
                                  amityjones71@gmail.com
P.S.
      The above features may have been set remotely by a
   nefarious (or somewhat knowledgeable) individual - remember
   that a little knowledge is a dangerous thing (even for
   FAXes). See (extensive) remote programming instructions
   on p.6-6 of the User's Manual.
        To print out the caller ID list - and possibly find out the
   source of the remote programming:
   Menu/Set,2,0,3 <up/down to "print report">, Menu/Set,
    Start, <Caller ID report prints>, Stop/Exit
   Ref: Brother Fax-2820 User's Guide p.A-3
Dec 20, 2007 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
23 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
