Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Our Trusty steed HP 8500 has just started to print a thin twin line and other spurious marks on the top side of prints. Today i replaced the drum / fuser / other bits but no difference any ideas?
  • 100 Answers
I have looked at the manual but there are so many possibilites! You can download the manual here and go to page 148 (PRINTING QUALITY PROBLEMS).
Initially I would follow the directions for clearing drum related errors:
Dark or white lines or streaks in all colors, including black.
Print the configuration page five times. The defect should clear
with continued printing. If the defect does not clear, turn the
printer off and on to reset the printer’s density calibration. If the
problem persists, replace the imaging drum. For more
information on replacing the imaging drum, see the installation
guide included with the drum kit.
Then clean the density sensor.
To clean the density sensor
Open the upper right door.
2 Use the brush located next to the
sensor to remove all toner particles
from the sensor.
Note
You can also use a hand wipe to clean the
density sensor. To prevent scratches on
the sensor, do not use any paper products,
such as tissue or paper towels, to clean the
sensor.
3 Close the upper right door.
It could possibly be a problem with the transfer drum.
I am sorry this is not of much help!
Posted on Nov 13, 2009
When printing from my HPLaserJet p2035n I am getting ink transfer lines down the sides
It sounds like you are getting ghosting and either the Primary charge roller or the OPC (drum) are deteriorating. If the cartridge was an original, it is probably due to be replaced. If the cartridge was a refill, you should contact the company you got it from and have it checked.
Apr 08, 2014 | HP Office Equipment & Supplies
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
When i print.It has a thin line on the right side
A vertical line on every printout usually indicates of a defective photo drum.
HP Laser Printers designed with the photo drum and toner cartridge as one unit.
I would try to replace the cartridge to resolve this issue.
Hope this helps
Mar 10, 2011 | HP Office Equipment & Supplies
Problem for HP Color LaserJet 8500 Printer Black line on the left side printed page while making copy on HP. This problem occurs only while loading the page on the top tray HP 8500 printer. No black line...
This is usually caused by something on the scanner glass. Check for dried ink or correction fluid on the scanner glass. We have a short article about solving this type of issue posted here: http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | HP LaserJet 8500 Color Printer
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
Apr 10, 2010 | Computers & Internet
Hp 8500-printing yellow lines across photo prints
I have an HP 8500 printer. When printing photos it prints lines spaced 1" apart accross the entire photo?
Dan
Oct 31, 2009 | HP LaserJet 8500 Color Printer
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
329 people viewed this question
Seeker5211
Seeker5211
