Question about Eddie Bauer 3-In-1 with Latch
How to thread the straps? - Eddie Bauer 3-In-1 with Latch
    Problem Solver:
  • 5 Answers
After heavy digging, I found the instruction manual for my Alpha Omega Elite 3-in-1 Car Seat #22-755-MAC and scanned it. If you are still interested, let me know your email address and I'll send the section that covers the straps. The entire document is about 8MB. I can send that if your email service can handle it. On the other hand, if you know of an ftp site I can drop it on, let me know.
Posted on Dec 14, 2009
How do I attach the wrist strap to the Canon PowerShot D30 camera
The wrist strap has a thin loop on one end. Thread this thin section (like threading a needle) through the strap hole. (It's on the left side of the camera. There are two openings with a bar over the top of the center of them at the bottom corner of the camera body.) Start threading from the middle of the body of the camera and push the strap towards the bottom of the unit. You may need to twist the loop to narrow it and keep it tight. Once you have this narrow loop through the camera, open up the loop and slide the thick material through the center of this thin loop. Pull the wrist strap until the thin loop tightens around the bar.
This is shown on page 12 of the D30 manual. The manual is available from Canon support on the Powershot page: http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf. The direct link to the manual is http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf .
I hope this helps.
(Many lanyard straps for electronic gear work the same way. Threading the narrow section under that bar does require decent near point vision. People who are far-sighted may need to wear bifocals or ask someone younger to assist.)
Feb 18, 2017 | Canon PowerShot Cameras
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
Rear gas tank strap bolt spin's but doesn't come out.
Bad news! Either threads are stripped, or where bolt screws in, the nut that is sometimes spot welded to hold bolt has come loose and is turning with your bolt. I would cut head off bolt, remove strap, and remove tank. Then you can see what you are dealing with. Use a little ingenuity to figure a way to make the strap hold good, when you put it back together. Good luck. If threads are stripped, and you don't want to have it tapped for new threads, try a smaller (high-grade) bolt with a nut to try and draw the strap up tight.
Oct 30, 2011 | 1999 Chevrolet Blazer
How do I install the wrist ******** my vivitar vivicam 5022?
The wrist strap hole is on the upper right corner of the outside body when you are looking through the viewfinder. Thread the skinny end (or one end) of the wrist strap through that strap hole. As soon as a little loop (like 1 inch) is poking out the other side, thread the thicker (or the other) end of the strap through that loop that's poking out of the strap hole. pull tight.
PLease "accept" so i get credit!! Thanks, Scott
May 27, 2011 | Vivitar ViviCam 5022 Digital Camera
Can't get the crank pulley loose. is it left our right threads. i am replacing the water pump.
TURN CRANKSHAFT BOLT COUNTERCLOCKWISE TO LOOSEN. YOU HAVE RIGHT HAND THREADS.ENGINE TURNING CLOCKWISE.YOU NEED A STRAP WRENCH HOLD CRANKSHAFT PULLEY WHILE LOOSEN IT.BUT YOU NEED A CRANKSHAFT DAMPER REMOVAL TOOL.OR HARMONIC BALANCER REMOVAL TOOL.YOU NEED STRAP WRENCH TO HOLD CRANKSHAFT PULLEY WHEN TIGHTEN IT.TORQUE CRANKSHAFT PULLEY BOLT 90 - 98 FT LBS. MAKE JOB EASIER.HAVE A HELPER HOLD STRAP WRENCH WHEN YOU LOOSEN OR TIGHTEN CRANKSHAFT PULLEY.
Sep 19, 2010 | 1995 Mercury Villager
How do I remove the straps so that I can lift the straps for a bigger baby?
The straps are usaully threaded through the back and a large buckle holds them in place, if this is the type you have you just thread the buckle through to the front and then lift starps and thread through to the higher hole. failing this take it back to where you bought it and ask, or if you bought it off the internet take it into your nearest baby item seller and they will be able to show you.
Jul 07, 2009 | Evenflo Embrace
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
Need instructions on putting together
Here's a link to a photo of the Century Breverra. From the photo at this website, I was able to figure it out. http://www99.epinions.com/review/Century_Breverra_Ascend_Sport/content_22722481796
First, thread the strap through the piece that clicks into the crotch point. Then, thread the strap through the **** on the seat just to the side of the crotch lock. Run the strap under the chair and through the **** on the opposite side of the bottom of the lock. Then, run it through both sides of chest lock, up through the shoulder points and lock it in the back. You're done!
It's not very eloquent but hope it helps!
Dec 30, 2008 | Baby Gear
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Strap on Panasonic DMC FX3
take the small loop and thread it through the strap hole, then pull the long loop through the small loop.
Oct 16, 2007 | Panasonic Lumix DMC-FX3 Digital Camera
Eddie Bauer 3-In-1 with Latch Logo
356 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Joyce Nokleby
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
