Question about Edu-Science (10166) Telescope
HOW TO OPEN THE FRONT COVER?EVERY THING'S BLACK!!!!!
  • 3,186 Answers
The lens cap either unscrews or simply pops off.
Posted on Nov 13, 2009
  • Joe Lalumia aka TelescopeMan
    Also DO NOT use the 2x barlow if you have one. It gives too much magnification for that size telescope. Put the eyepiece with the largest number written on it into the telescope. Go outside during the daytime and practice focusing on a distant object. The moon should be your first target at night.
How to add engile oil
open hood , the cap turns off left loose right tight .oh it is on the top of the big black valve cover it is the only thing on there
Feb 20, 2015 | 2009 BMW 5 Series
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
My motorola phone's screen keeps completely blanking out...i mean u can tell the backlights on, but i can't see n e thing but black
pop the front cover off and check to make shure that the conections to the screen are still secure..also remove the battry cover and take the battery out..see if where the phone piviots to open and close thet the ribon cable isnt hanging up
Mar 11, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Paper jam
This is a very easy fix.
  • First, open the front cover.
  • Next pull out the black thing that is right there.
  • The cartridge is inside of the drum, and the drum is what you need to pull out.
So basically, when you open the front cover, you need to pull out the thing you see, and you need to pull it upwards for it to come out. The paper should be under it or behind. Hope this helps! If you need pictures, just email me-eran_4h@hotmail.com. GOOD LUCK!
Feb 01, 2010 | Brother MFC-7440N Laser Printer
Unable to remove imaging drum - Dell 5110cn Color Printer
When you open the front cover it is possible for the transfer roller assembly to remain latched against the imaging drum assembly, making it impossible to pull out the imaging drum. The drum should lift out very easily. If it doesn't, try closing the imaging drum cover and then the front cover (ie: put everything back the way it was). Then open the front cover again, pressing firmly on the front cover latch. When open, check that the transfer roller assembly stayed with the front cover and swung out of the way of the imaging drum (you may have to swing it yourself. When the front cover has opened properly, the imaging drum's cover will unlatch easily and the drum can be pulled out.
I hope this helps someone! I had to say many bad words before I figured this out. Good thing I had a second 5100cn handy to look at for comparison. - B.Till
Nov 06, 2009 | Dell 5110cn Laser Printer
Where is the toner waste bottle?
open up the front cover which will hinge down under the front display panel. The waste toner bottle is the black plastic thing under there.
Theres a blue catch to release it.
Oct 21, 2009 | OKI C9650HDN Led Printer
Bizhub c352 not printing black. I change the catridge still not change. please help.
The toner is not install properly. At the front end of the toner cartridge has an opening and a slide cover when you push the cartridge. underneath is the black developer unit which it has same opening and a cover some tines the Spring of those two opening cover might come of or tech intentional removing the spring so the opening stay open. but those two opening cover have to engage to open each other to open permitting the toner to drop to the developer unit. examine the the front end of the developer unit and toner cartridge slide covers.
Jul 04, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Maytag M3X05F2AK air Conditioner -BLACK CHUNKS FLYING OUT
remove front cover and clean the coils off with a nylon brush. make sure filter is clean. with front cover off take it outside hook it to an extension cord and set it on the floor. then let it run till the stuff stops coming out. if you want to open the whole thing up you could clean it out even more example being the inside fan area behind the coils, but the first option should work.
Jun 05, 2009 | Heating & Cooling
Lamp replacement
Sure, I do by myself. Seat on the floor in front of the TV
!st. step: Grasp both side of the silver front cover with your
fingertips and pull it from projection display.
Then remove it.
2nd. At your left hand you can see a black knob. Turn the
open/lock knob to the left. Pull the black unit that have
the lamp inside. Cover out and down to open.
3rd. Loosen the lamp (black unit) screw with screwdriver.
Grasp the handle of the black unit lamp and slowly
remove the unit.
4th. Insert the new lamp black unit being careful. Tighten the
black unit lamp screw with a screwdriver.
5th. Close the lamp cover. Turn the lock/open knob to the
right.
6th. Replace the silver front cover. Finished.
R. Vega from Puero Rico
Apr 28, 2009 | Panasonic PT-52LCX65 44" HDTV
Edu-Science (10166) Telescope Logo
99 people viewed this question
Top Edu-Science Optics Experts
Craig Butler
Craig Butler
john cordey
john cordey
Geoff White
Geoff White
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
