Question about Siemens Dishwashers
An electrician switched off the power whilst doing other work. Power was restored OK. But when we came to use the dishwasher there appeared to be no power to it i.e the control panel remained blank. We have checked the fuse box and all appears to be in order.The appliance is a Siemens FD 8909 dishwasher
  • 4 Answers
Maibe the internal fuse of the dishwasher blow for a spike, check first if you have power at the socket if so is highly posible that you have a blown fuse in the dishwasher
Posted on Nov 13, 2009
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
Dec 23, 2013 | Leviton Vizia + VP00R-7LZ Accessory Dimmer...
My Neff integrated dishwasher has been used 5 times and now no power lights coming on and nothing happening. This is a new build and purchase is out of warranty as we have just moved in 2 years on. The...
the only thing i can say is that you should ring up the company and tell them what is happening and ask them can they tell you what to do
Sep 03, 2012 | Dishwashers
I just installed the dishwasher and do not turn on
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
May 20, 2010 | LG LDF6810ST Stainless Steel Built-in...
No electricity getting to dishwasher
check connection at connection box under dishwasher behind lower pannel was ther power to the switch some dishwashers have a thermal fuse in the console white plastic whith two wires going to it
Jul 02, 2009 | Westinghouse Dishwashers
Maytag dishwasher mdb7601 will not run-
if power to the dishwasher is OK, then the door latch may be the problem. You need to unplug the unit, remove the inside cover to the door and check the door latch switches (may be a pair) with an ohm meter for continuity. Each switch is a make/break connection. If that is OK, the problem could be a power connector to the control circuit board that could be loose.
Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Dishwashers Logo
539 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
