Question about Vacuums
How to change belt on Hoover DM6227T - Vacuums
  • 328 Answers
Hi Diane
There are two options here; Go to the Hoover UK website and download the user manual (http://service.hoover.co.uk/manuals/Manuals.aspx?Section=6) and add in the DM6227 code and number without the T letter. The pdf downloadable (and free) user manual will upload to your computer.
Or follow this method:
There are two rear screws on the top of the hood of which you'll have to swing the handle all the way down to reveal both screws at the back of the top hood. Undo these screws and put them in a safe place. Then gently prise off the main control selector height dial and the top hood should be able to pop off easily. Then you'll main roller brush should be revealed as well as the broken belt.
Once the belt is removed, clean the brush roll of any threads or hairs that have stuck the bristles down. Then fit new belt, align the roller bar properly including the new drive belt and then refit the top hood back on, snap fitting down, two screws in and gently refit the control dial height adjuster back on making sure the front raised part of the dial knob is facing the Hoover.
Anything else don't hesitate to contact.
Posted on Nov 20, 2009
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do you change a burnt belt for hoover u5269
If you go to this link you will find the belt you are looking for and you can also view the manual, which has step by step instructions on how to change the belt. Good luck!
Hoover EmPower U5269910 Belt and Manual
Oct 26, 2009 | Hoover U5269910 Bagless Upright Vacuum
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Vacuums Logo
119 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
