Question about Lexmark X500n Color Laser All-in-One Printer
Lexmark X500N says replace transfer belt, what is it, and how do I change it?
    President:
  • 1,015 Answers
The transfer belt is located inisde the printer and is what moves the paper back out the printer. You will need to open the back cover of the unit then you will lift the top part of the printer off. This will expose the transfer belt. There is a bracket holding the transfer belt with two screws that will need to be removed. Then two more screws that are holding the belt assembly in place. Once those are removed then you can slide out the transfer belt assembly. The new replacement transfer belt assembly will slide back in replacing the old one. Then repeat the steps opposite to install. Then remove the four spacers on the new belt(on each corner). Then you will reset the counter for the belt and will need to run the printer alignment settings.
Posted on Nov 13, 2009
When trying to scan on our Lexmark x500n using Presto PageManager, I get an error message that says LMABHW.ini open error. Please install again. We have uninstalled both the printer and program and have...
Please download and installed the updated scan drivers.You may go to support.lexmark.com and select the Lexmark X500 Series SystemAdministrator Package, the local TWAIN is included on this. For further assistance, please contact LexmarkTechnical Support.
Apr 11, 2011 | Lexmark X500n Color Laser All-in-One...
I cleared an paper jam in the rear and when i restarted, it has an error message, missing transfer belt. nothing has changed
if you are sure nothing has been changed then there might be a small peice of paper blocking the transfer belt sensor
try manually rotating the rollers where possible near the problem area and also try to blow some air with pressure to remove any torn bits of paper
hope could be of help
Mar 28, 2011 | Lexmark X500n Color Laser All-in-One...
Lexmark x500n keeps on saying CPU FAN LOCKED on the display.
HI there please reset the printer and turn of for 10 minutes. After that turn on try. Let em know the result.
Feb 15, 2011 | Lexmark X500n Color Laser All-in-One...
My Lexmark x500n Don,t accept new Toner. i get allways error messages What can i do?
What error message you are getting when you replace the toner? please provide us information and wed be glad to assist you.
For further assistance, please contact Lexmark Technical Support.
Jan 25, 2011 | Lexmark X500n Color Laser All-in-One...
I have replaced my Lexmark X500 transfer belt but I cannot reset it to get the replacement message to go away and the maintenance page still shows the transfer belt as out.
Please try to check if the transfer belt is properly installed. Turn off the printer for at least about 30 seconds.
If you need further assistance please contact Lexmark Technical Support Center.
Jan 20, 2011 | Lexmark X500n Color Laser All-in-One...
RESET FUSER X500N
Here's an article found in the Lexmark website on how to reset the the Fuser page count on X500/X502. Just click on this link: http://bit.ly/aCr2dx. Hope this helps.
Jun 04, 2010 | Lexmark X500n Color Laser All-in-One...
What is the lexmark belt, when i get a message the belt close to life , what is that mean
The part you need to get is called a transfer belt. This piece is how the printer transfers the toner from the 4 color cartridges to the paper. The transfer belt is a consumable item that has a life of about 12000 pages. The parts number for the belt is 40X3418
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Lexmark X500n Color Laser All-in-One...
Lexmark x500n paper jam
Try cleaning the roller that picks up the paper. You can use a drop of alcohol to clean the roller.
Feb 07, 2010 | Lexmark X500n Color Laser All-in-One...
Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Mar 18, 2009 | Lexmark C522n Laser Printer
Code E9 Service Call and Disgusting Sound
the photodeveloper cartridge needs to be changed.
i have two of the same printers. after swapping the photodeveloper cartridge, it worked again..
Jan 08, 2009 | Lexmark X500n Color Laser All-in-One...
Lexmark X500n Color Laser All-in-One Printer Logo
1,233 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
