Question about Olympus 8.0MP Digital Camera Holiday Gift Box: Camera, Case and Memory Card - Blue
The latch on the camera door is broken. Can it be replaced?
    Scholar:
  • 83 Answers
Sure.
Replacement covers on their own rarely surface on ebay, but you might be lucky and find a "donor" camera with a working cover - it will probably work out cheaper than trying to order directly from olympus or their parts department.
The battery cover is attached to the back cover of the camera, you'll need to unscrew it (make sure you take notes of which screws go where as they are not the same).
Hope this helps,
Good luck,
Raf
Posted on Nov 13, 2009
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Film door latch broken
Nikon doesn't supply the film door any more. You can buy a repair kit from USCamera.com to replace the latch on the film door
Jan 02, 2010 | Nikon N6006 35mm SLR Camera
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
How to replace the door latch on a canon rebel eos ti
The cameras film door has a very small phillips head screw inside the battery doors hinge. Its a pain to take out & replace if you hands are shakey for this screw is so small. Also installing the replacement hinge would be a little harder to install tha removing the broken one.
I hope this information will help you. A camera shop should be able to do it for free if you maybe purchase some items there. Most shops which are very small and privately owned shops will do this for you
Mar 03, 2009 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
Kodak camera dx7630
Gaffer tape is the answer no likely any spares are available
Jul 02, 2008 | Kodak EasyShare DX7630 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
Mar 15, 2008 | Nikon N65 35mm SLR Camera
Olympus 8.0MP Digital Camera Holiday Gift Box: Camera, Case and Memory Card - Blue Logo
65 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
