Question about GE Dryers
Ge dryer model DVL223EA0WW service manual to replace heating coil
Need ge dryer model DVL223EA0WW service manual to replace heating coil
  • GE Master
  • 7,482 Answers
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
Service manual dbxr463gboww
You may not need a service manual. Lots of help videos on youtube.
GE DBXR463GB Gas Dryer no heat YouTube
Aug 25, 2014 | GE DBXR463GB Gas Dryer
DVL223EA0WW. THe electric strips come on before the a call to Start
The heat strips were grounded. They had come out of the ceramic clamps. I had to remove the tub.
Sep 05, 2013 | GE Dryers
I have a GE DVL223EA0WW dryer, it makes a loud screeching sound when it runs
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 06, 2011 | Dryers
I need to find where the fuse is in my GE profile gas dryer DPGT750GC1WW. WE need to find this because our heat doesn't work so we need to replace the fuse
The model number you gave is for a gas dryer.
You will not find a thermal fuse in this dryer.
Your problem with no heat most likely lies in the gas valve or its subcomponents like the thermistor/flame sensor or igniter/glow coil.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer stopped heating
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 03, 2009 | GE DSXH43EF Electric Dryer
Dryer heats once or twice then stops heating
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001348.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 3-10 of the manual listed at the link below. Operation and replacement of coils is covered at page 3-32. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble. Good Luck
Maytag Dryer Service Manual
Sep 15, 2009 | Maytag Dryers
Dryer is not heating, only blowing cool air
Its best to take it to an appliance repair man. This is usually an electrical problem related the the board or the relays behind the control panel. Beware though, sometimes its cheaper to buy a new one than fix the old. Hope this helps.
Sep 13, 2009 | Uniden Cordless Phone
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
How do I test for bad thermastat or heating element on GE dryer
well the fact that hte heating elemnt is glowing tells me that all the thermstats are working, i would check for a blockage/restriction in the venting. looking at te diag, its possible that only 1 of the 2 coils for the heate are actually going on, check the coils for continuity( may be a small break that separates when gets hot)
Dec 07, 2008 | GE DCSR483EA Electric Dryer
I'm really not stupid....really
hi,
you could try a limiter out of an old hairdryer or heater and solder it in and jb weld it to that spot. I did that to ours and it works to this day. I was recycling cans at the recycle center and saw at least 4 or five nearly new washing machines and dryers there, I was in shock, but you might find a limiter there also. Use your own discretion on the fix above and run the machine through several heat cycles. Never run your dryer and leave the house either..
good luck
J
Aug 28, 2008 | GE Dryers
Dryers Logo
841 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
