Question about Bloomfield 8571 Coffee Maker
Bloomfield 8540-When doing pour over, ready light never comes on and water keeps heating. Unit puts out alot of steam. Unit will produce a hot pot of coffee.
    Problem Solver:
  • 11 Answers
The thermostat could be faulty or out of adjustment. To adjust it (on my 8572) unplug it, remove the top, there is a box (black on mine) with four wires and a copper tube which goes into the tank (temperature sensor) which has a half enclosed tube sticking out of it with a small screw inside. Remove the small rubber hose from the top of the tank and place a thermometer into the tank through the hole. Turn the sdjusting screw counter-clockwise until it stops (check the +/- signs to be sure) and plug it back in to see if it will shut off before boiling...***MAKE SURE NO WIRES ARE SHORTED BY THE THERMOMETER AND DO NOT REACH INTO UNIT WHILE IT IS PLUGGED IN DUE TO SHOCK/FIRE HAZZARD*** if it stops heating before boiling, turn the adjusting screw clockwise a bit at a time until it shuts off at 205 degrees faranheit and reassemble the unit. If not replace the thermostat.
Posted on Dec 01, 2009
Bloomfield pour over Model 8543...Taking very longto brew....How long should it take?
Call for service! Repairs should be performed by a qualified Bloomfield tech.
*** the following is for information only ***
* Your brewer has a tank that should have 1-1/2 pots of pre-heated ready to brew water. Pouring in a cold pot of water will push out the heated water into the funnel and over the coffee grounds then into the decanter. This should all start within 15 seconds of pouring water in machine (the top opening) and continue to brew for about 2 mins with a drip out for another minute. If your getting cold or luke warm water out of the brewer then you didn't give it enough time to pre-heat (about 20 mins.) Still not hot? Then call your vendor for service.
* If brewer was not pre-filled prior to powering up then the Thermal fuse may have blown due to no water in tank and/or over heating.
* Depending if the tank was empty and how hot the element got will determine what blows.
* If it was completely dry when plugged in then the element got cherry red hot and may have melted gaskets as well as all the fuses.
* Depending on the model, there may be 2 thermal fuses or even a 3d on the thermal blanket.
* If the brewer was filled but left on for a long period (weeks?) then the tank just boiled off till the fuse blew. Good chance the element is ok. But have to check to be sure.
* Pre-Heated tanks like this unit.usually have a normal load on from the warmer blanket. The load (amps) will kick up on the initial heating of the tank (filled with water) then drop down after reaching temperature.
* There is an additional load if any warmers are turned on.
* Some brewers have a separate heater switch (some call it a 'Vacation') on/off switch on a brewer will activate the main heater element. Some have a separate switch for the brew warming plate (Blanket stays on all the time)
* Easiest way to check is amperage loads on each section. Continuity is a bit harder as it does not tell you if it's shorted (unless you know the resistance loads to begin with)
* Final: Get a qualified service tech to check just to be safe.
Aloha, ukeboy57
Feb 03, 2018 | Bloomfield Coffee Makers & Espresso...
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Lights not working no hot water
You should contact Bloomfield to find your local Bloomfield Service vendor. You will need them for parts and/or service.
*** the following is for information only as all repairs should be performed by a qualified tech.***
The start switch activates the timer (analog or digital) board which turns on the water feed to the brew tank. This forces previously heated water out and sprayed over the ground coffee in the brew funnel. Coffee then drips into the decanter.
* This brewer has a tank that needs to be filled PRIOR to powering up as the heater element usually turns on as soon as it's plugged in. The thermal fuse(s) will blow if tank is not filled. Once filled and powered up. Wait 20 mins then set up a coffee funnel and decanter. Slowly pour in 1 pot of water into the top opening. Do Not splash or over fill! Water should come out of the funnel and fill the pot (full). If it's not hot then the element is not working and this unit will need service.
* Check if there is an on/off heater switch on the back or side. (some are 'Vacation' switch) Turn on and wait 20 mins for another pour over brew. If it still does not heat then the limit fuse(s) are blown.
* Check the on/off switch. Most models will light up when switched on.
* Check the timer. Digital timers tend to be sensitive to electrical storms. Analog timers have a dial and are more tolerant of electrical surges.
* If you do get a good heated brew then continue to use as a pour over or hook up the water line to the brewer. (usually a 1/4" copper line with a flare or compression fitting.)
* Check the water fill solenoid. Should be a definite click when activated. Water filling sound should be very clear.
* No water flow then check the water supply line if it's on.
* Final; this brewer needs service. Call your coffee vendor for advice.
Aloha, ukboy57
Nov 08, 2013 | Bloomfield 8543 Coffee Maker
I recently purchased a bloomfield 8572 on ebay and it is in pretty rough shape. i eventually want to hook it up to my waret line in my kitchen but my first test using the pour over didn't work. I...
* But since the water line was not connected then the buzzing sound is just the valve opening.
Aloha, ukboy57
Sep 26, 2017 | Bloomfield 8572 Coffee Maker
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
Nov 04, 2009 | Bunn Pour-O-Matic VPR
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Water does not displace...
if you give us the make and model we'll see what we can find for you.
Jan 05, 2008 | Bloomfield 8571 Coffee Maker
Bummer Bun
The pour-over type of Bunn coffee brewers require several pots of water to fill an empty tank.
1. While unplugged, pour in two and a half to three pots of clean water (put an empty pot underneath the brew basket). When the tank is full, water will come out of the brew basket.
2. Plug the unit in and wait for it to heat - about 5 to 7 minutes. These brewers are meant to be left plugged in all of the time to keep the tank water hot. You will probably heat some rumbling noises which is normal as the water heats.
If for some reason the water isn't hot after 10 minutes you will need to check the thermostat. Unplug the machine and take the screws out of the top. The thermostat has a little dial or a t-bar that you can turn. All the way left is off and all the way right is boiling. Turn this up about 90% of the way and put the top back on the machine and plug it in. If it gets hot, you are ready to brew. If it doesn't get hot, you may have blown the limit thermostat and will need to replace it.
The limit thermostat isn't the same as the thermostat. It is a ceramic and metal item that senses if the tank gets too hot from having the unit plugged in without any or enough water in it. It is inexpensive and relatively simple to change.
Nov 25, 2007 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bloomfield 8571 Coffee Maker Logo
151 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
frankecoffee
Level 1 Expert
rhodesworks
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
