Question about Logitech Cordless Mouse
Logitech M700 Mouse recharging problem
When I put my M700 Logitech Mouse into its cradle to recharge, it doesnt. Both A1 green light and F lock green light is showing but the batteries quickly die during the week so I have to recharge them separately - what is the problem?
  • karja Jan 10, 2008
    Thanks I will try this.
Try replacing batteries by newones,since they are ni-cd type,they do have limited no.of charge/recharge cycles and tend to lose performance with time.
Posted on Jan 09, 2008
6ya staff
SOURCE:
How do i charge the mouse
Has it got a housing? If not, then you'll need to open it and either recharge (if rechargeable) or replace the batteries.
Feb 14, 2015 | Logitech Cordless Mouse
Mouse has flashing red light. What should I do?
Does the mouse still work? It could just be the low battery warning, ensure that it goes to green when you put in on charge (or put new batteries if its not a rechargeable one)
Oct 29, 2010 | Logitech Cordless Mouse
My Logitech mouse is wireless # CE0682 and the red light on the mouse is always flashing, even when on the receiver. I also have some problems when I want to use the mouse to hilight a block of text, as I...
Gina, I've had my Logitech ce 0682 for years and have had some similar problems. The mouse is supposed to rest in the cradle and recharge the batteries, but I've noticed that it rarely works for me. The connectors on the mouse seem to scuff and corrode easily and I'm sure that degrades its ability to charge batteries. So my solution was to buy a 4 pack of rayovac rechargable batteries(AA) and a usb battery charger. I never put my mouse in the cradle now and keep 2 batteries recharging at all times so I always have fresh batteries when that pesky red light comes up telling me the batteries are dying. As far as your highlighting text problem. Sorry don't have a solution on that one.
Sep 03, 2010 | Logitech Cordless Mouse
I have a logitech cordless mouse that does not charge when placed
either ur cradle or ur battery hav been damaged...
try changin it...
Mar 11, 2010 | Computers & Internet
My Logitech Dinovo Edge is not recharging. When I put it in the charger the battery charging indicator light flashes red instead of green.
Were you having problems with short battery life before this happened? Most of the time if the battery is not recharging it needs to be replaced. Have never seen the red flashing light before though. It may mean that the battery has shorted out.
Jul 24, 2009 | Computers & Internet
My batteries won't recharge. Normally when it recharges it blinks green, with the same speed as when it's low on power. But when I try to recharge it in the cradle, it seems to charge for a few seconds,...
Without knowing how long you have been using the mouse it's hard to say. But, my first guess would be that it is time to change the battery. Rechargeable batteries don't last forever.
Nov 03, 2017 | Logitech Cordless Mouse
Stopped recharging
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Aug 05, 2008 | Logitech MX 700 Mouse
Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Logitech Cordless Mouse Logo
1,152 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
