Question about Dell Inspiron 1521 Notebook
I am trying to backup my photos onto disc but get error e/drive not accesable when opening the drive
    Scholar:
  • 181 Answers
Check whether the cd driver is working properly,check status of the disk is good,insert other disc and check hether it is accessable, only possible way you can take backup of your photo is .you have to burn the photo files using the nero burner software.
Posted on Nov 13, 2009
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
DISC CRACH
If your hard drive is "crashing" and you can still access it, copy any important files off of it thay you want, like docs, pictures, music, etc... From there, you need to replace the hard drive, they are not extermely expensive and easy to install. If this is your main drive with your OS on it, you will then have to reinstall windows or whatever OS you have, then copy your files onto the new hard drive. If you cannot boot up because it is your main drive and has already crashed, your best bet is to get a new one and reinstall your OS, then get an external hard drive reader and try to access it and get your files that you want. If it is crashed, not accesible, the only way is to take it to an expert, which is very expensive. Unless these are "must have, can't live without" files, you probably will just have to take your lumps on losing that data. Either way, when your HDD starts to go, it is usually only a matter of time before it totally crashes so a "repair" or quarentining any bad sectors is only a band aid and will eventually, sooner than later, die on you all the way.
Sep 27, 2012 | Computers & Internet
My hard drive has just stopped being recognised by my computers.The computer knows when i plug in but the hard drive does not show up in my computer. The green lights flashes internittently but not...
I had the same problem, This is what I did to fix. get a recent copy of a live disc from linux, run and boot from live disc, I used puppy linux as is small and can run from ram completely, after puppy is up and running you can mount the drive your trying to get photos off, find the photos and copy the not move, to either a portable flash drive or to the c drive acceses through puppy mounting utility, after copying all the photos you require then formatt the drive in linux puppy to ntfs, after this is done shut down puppy remove puppy disc and restart copmuter back to windows and the drive should be accessable once again, I hope this helps
Feb 13, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Sony Vaio VGN N320E won't start - recycles to error window have a vista repair disk - doesn't seem to work - trying to save precious photos before ordering recovery disks from Sony Would like it to start...
You can backup the data and restore it to factory settings.
Please restart the Computer, press the F10 key at startup to access the Recovery Center.
Select Rescue Data option to backup the data to an external USB Hard Drive or thumb Drive or CD/DVD Disc..
Select Custom Rescue Data option to backup the individual data.
Once the data is backed up, select Restore C Drive option to restore the Computer back to the factory settings.
Apr 18, 2010 | Sony Computers & Internet
How do i clone my hard drive onto an external hard drive
Are you using Windows? If you are using Windows, go to Start => Programs => Accessories => System Tools => Backup. In the backup wizard that opens, choose which backup type you want and you can choose your backup destination. Choose your Seagate Expansion external drive for your backup location so that Windows can store an image of your current system into your external drive.
Feb 09, 2010 | Computers & Internet
I want to put photos from my camera onto my laptop but my laptop is an old one so no disc can i do this without disc no slot for disc
Then Transfer the Photo from the Disk Onto a Flash Drive (USB Storage Drive)... And plug into the old laptops USB port then transfer photos
Nov 15, 2009 | Dell Latitude D600 Notebook
NO disk error Exception Processing Message
if the usb drive when trying to access it says insert disc, the usb drive was not 2gb. if you can test it with "H2testW" google this.
if during test unit comes back as fake, there is one program that might work to restore it to correct specifications. good luck!
"PD V1.08 B3"
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Data recovery from corrupt external hard drive
download and install R-studio ntfs this run r-studio ntfs then locate drive in screen then scan drive It will take awhile to scan once scanned you may open the scanned drive let it search for all files to be recovered then just place a tick by the files or folders to be recovered then click recover then select destination folder then click the appropiat button and wait for allfiles or folders to be recovered.
good luck
Jun 28, 2008 | Western Digital Caviar WD2500BB 250 GB...
Dell Inspiron 1521 Notebook Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
