Question about HTC Touch HD Smartphone
My phone just started freaking out. I can no longer see my home page screen. All I can see is the calendar and contacts. Assume I need to do a hard reset so I have 2 Qs: 1. Have you heard of this problem before and is it serious? 2. How do I do a hard reset? Many thanks, Paul
Why do I keep being asked to re-enter a password for Yahoo! on my 5c?
To set up a Yahoo! Mail account for sending and receiving emails in iPhone Mail:
  • Tap Settings on the iPhone Home screen.
  • Go to Mail, Contacts, Calendars.
  • Tap Add Account... under Accounts.
  • Choose Yahoo!.
  • Tap your name under Name.
  • Type your full Yahoo! Mail address under Address.
  • Enter your Yahoo! Mail password under Password.
  • Tap Next.
  • Make sure Mail is ON.
  • Tap Save.
  • Press the Home button.
Nov 08, 2014 | Apple iPhone 5
How to do a hard reset on cell phone
Pull out the battery to make sure phone is turned off. Press and hold the Volume Down button, the Green Send button and the Red End button at the same time. Then follow the instructions on the screen to hard reset the phone. This will erase everything on the phone, so make sure you periodically sync your phone with your computer to protect your contact list, calendar, etc.
Jul 15, 2014 | HTC Snap S521 Cell Phone
My iphone zoomed in for no reason and now does not zoom out
If you've tried restoring to a back up, and it has not fixed the problem, that indicates the error has been backed up to your most recent iPhone backup. If you're trying to avoid doing a full restore, i would recomend going to an older backup, that may preserve your contacts and calendars.Hope this helps, and good luck!
Oct 06, 2009 | Apple iPhone Smartphone
My calendar program is missing..
IN MENU--> SELECT BLACKBERRY LOGO BUTTON--> SELECT SHOW ALL.
1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
Click Hide Icon.
2.To show a hidden icon on the Home screen, complete the following steps:
Press the Menu key. Click Show All.
3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
Select the transparent icon on the Home screen that you want to make visible.
Press the Menu key.Cancel the Hide Icon selection.
4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Lost contacts & calendar
You will need to reformat and go again...sorry
May 31, 2009 | Apple iPhone 3G Black Smartphone
Cect phone - no calendar
the problem you have is there is no java on this phone and also it is a none supported phone /your money would have been better spent on the i9 cect it has java and calender
Jan 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Contacts, Calendar & Tasks issues
You could try removing applications you installed, one by one with a power on reboot in between each removal, to see if an app caused the phone to do this. Start with latest app you added and progress to oldest you installed, trying to see if problem is fixed between each.
To Remove programs, go to Start/Settings/Remove Software.
If this does not work, you can Hard Reset your phone. This will cause original MFG software to reinstall itself. You will lose any apps or data you installed since new.
To Hard Reset, press and hold both left and right soft keys while turning phone on, till the Reset Screen displays.
Sep 14, 2008 | Audiovox SMT5600
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
HTC Touch HD Smartphone Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
