Question about Sony Computers & Internet
I have a sony VGN-SZ583N and sudenly don't boot any more. When I press the power botton, the green light is on, the hard disk light blinks and then off, and I hear the cooling fan works, but the screen is black. It is the motherboard problem?. I've been seen in some sites the same problems with old models, regarding the RAM sockets. But it seems it is not my problem. thanks in advance Leo (from italy)
SOURCE: M35X does not boot up
I had the same problem after trying to overclock a satillite. the laptop did the same things. I tried everything including using the recovery disk, upgrading mem and replacing the HD. in the end I had it sent back to toshiba through best by under warranty and it came back with a scratch on the screen buy it booted up and has been fine. this rig has an intel 1.6 centrino chip and intel board, also I updated the bios to 1.5 and shared video memory went from 128mb to 64 mb.Toshiba sent back a repair order with the comment "an internal was made". I have also seen comments about the loss of shared video memory and while I have seen statements that both intel and toshiba are aware of the problem there is no fix that I have seen
Posted on Nov 06, 2007
shakeelm
  • 224 Answers
SOURCE: my acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
Posted on Mar 16, 2009
benwabnick
  • 2404 Answers
SOURCE: Gateway MA7 black screen, no bios
Take out the hard drive, take out the dvd drive. If you still don't get any video, try another stick of RAM and if that still doesn't work, then the motherboard is definitely bad at that point.
Posted on May 24, 2009
LaptopExpert
  • 458 Answers
SOURCE: upon boot up, screen remains black,disk power up briefly
HOW TO FIX YOUR DV6000/DV9000/DV2000/tx1000/tx2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 04, 2009
SOURCE: Sony Vaio laptop vgn-fs640-w problems
That happenedto me one time but i pressed the either the S1 or S2 button right bellow the speakers and the screen came back on.
Reply if this works for you, if not... Im sorry.
Posted on Aug 06, 2010
Sony vaio laptop driver VGN SZ583N
Please give me Driver Link of Sony Vaio VGN-SZ583N
Jan 26, 2013 | Computers & Internet
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
Sony vaio VGN-A17GP not booting- 1 green light 2 amber are shown
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 16, 2012 | Computers & Internet
VGN-FS640W - Three green LED's come on but no boot up.
your hardrive is going bad cannot read the disk.take hardrive out and tap it slightly? then replace see if it makes a difference..
Jun 17, 2009 | Sony VAIO VGN-FS640W Notebook
Sony vaio blank screen
pls consider changing ur RAM issue will be resolved most likely ok let me know , there is strong chance ur RAM is faulty, if power comes but unable to start the system u see blank screen and no hard disk activity and light blinking then it is the RAM issue
pls rate me if i solved ur problem or explain ur problem in detail
Feb 27, 2009 | Sony VAIO VGN-FE880E/H Notebook
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
try to hard resset your phone' make sure your fully charge of the baterry'
hard reset' press * 3 green botton and power at the same time'
after it on and see the NOKIA logo blink release all the bottons and wait until it re-boot.
Aug 26, 2008 | Nokia 6680 Cellular Phone
VGN-NR220E won't boot up
Bad memory can cause a system to hang as you describe.
If it is accessible, remove the memory cards, swab them with cotton swabs and alcohol and try it again.
Don't put the cards back in while still damp if you use rubbing alcohol.
Aug 19, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
N 70
try to HARD RESET FORMAT
make sure your battery is more than 3bars,
just press the green botton, 3 ,* and power botton at the same time.
Don't release it until you see the Nokia blink and the screen turn on white' and then release all the botton you press.
wait untill your phone re-boot.
hope it will fiya your prob.
thanks for rating this solution.:D
Mar 11, 2008 | Nokia N70 Cellular Phone
Computers & Internet Logo
118 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
