Question about Samsung Jet S8000 Cell Phone
I get ascii numbers for names instead of letters on my mio s555 navigator-BT screen when imported from jet. phonenumbers are ok! b.t.w. moto-razr does it well!
Mio s555 wont load after accepting safety agreement
Connect to a PC and save the contents to the PC.
Format your Mio and copy back the contents.
Dec 18, 2014 | Mio GPS
How do I add my name to the number associated with the phone?
There should be an icon you can touch that will bring up a menu with "Edit." On my Moto G, it's three square dots stacked vertically in the upper right corner of the screen when I'm viewing my own contact info. Once you are in "Edit" mode, you should be able to add your name and other info as you wish.
Jul 30, 2014 | Motorola Mobility RAZR V3
How to set router password
Make sure that you are connected via ethernet cable or hard wired connection:
1. Open a browser ( internet explorer, mozilla firefox,google chrome or safari)2. Delete all of the characters in the address bar3. Type the numbers 192.168.1.14. Press enter.5. You will be able to view the modem settings page.6. Select Basic Setup or the second tab with the word interface.7. Select Wireless Setup8. Enter the SSID or (service set ID), this will be your wifi name.9. Select WEP or WPA for your router's wi-fi password.10. Select ASCII for the passworrd.11. Enter any password ( around 10 alpha numeric characters to make sure that it is a strong password)**alpha numeric means combination of letters and numbers.12. Select Save or Apply.13. Disconnect the network cable for you to test the Wireless password connection.14. Scan for new wireless network on the lower left hand of your computer's screen.15. Look for the wireless name that you entered for your SSID.16. Connect and it will ask you for the wireless / pre-shared key17. Enter the WPA password that you created ( the 10 letters and numbers that you entered for ASCII)18. Press connect.
there you go... you will be connected to your router via wireless with password protection. No one can connect to your router unless you gave them your PSK or wi-fi pre-shared key.
Dec 24, 2011 | Linksys Computers & Internet
My internet connection keeps dropping out with my new WL adapter. I installed a new Trendnet Router at the same time. The main computer seems to be working fine, but my wireless connection is worse than...
1)Open NETWORK CONNECTIONS from CONTROL PANEL
2)Right click on the connection and select PROPERTIES.
3)There should be a tab for WIRELESS NETWORKS.
4)Find your network by name near the bottom and click REMOVE.
5)Click ADD then you will need to enter your network information manually in the window that pops up. You will need to uncheck the box that says "My key is provided automatically"
SSID is the network name.
NETWORK KEY - This is the important one. get it wrong and click OK and when you go back in to modify it Windows screws up and saves it wrong. You can enter network keys in ASCII (typed letters) or the HEX that the router converts the key into. 5 ASCII/10 Hex is for 64 bit, 13 ASCII / 26 HEX is for 128 bit. Your key must be one of these 2 lengths.
Nov 04, 2010 | Trendnet TEW649UB Mini Wireless N Speed...
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
How to send a text message without my number showing up on the other persons phone
go to settings then go to display then go down to text settings or whatever it is called then change it
Mar 30, 2010 | Verizon Communications Samsung Alias Cell...
Map updates not available
mio supperted c220 until april 2007
Sep 28, 2009 | Mitac Mio C220 GPS Receiver
Password of lockin/unlockin my phone
i took a moto razr v3i mobile frm my frnd bt i frgot 2 ask password wat sud i do??????/
Apr 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Installing mio pocket on Sanyo 4370
Use SDFree method and assume you have extracted MioPocket on your PC's local drive
  1. Hook up your GPS to a PC via USB cable and note a drive letter
  2. Copy MioAutoRun, SDFree, and Media folders to the root of GPS FlashDrive (drive letter) above
  3. Open MobileNavigtor and rename MobileNavigator.exe to MobileNavigator_orig.exe
  4. Rename all 3 files begin with Miomap in SDFree folder to MobileNavigator (keep the extension intact)
  5. Copy all 3 files and MortScript.exe to MobileNavigator folder
  6. Unplug the GPS and launch MioPocket via the Navigation button. MobileNavigator on top is Sanyo GPS apps.
HTH.
Feb 18, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Sat nav maps/gps not working on MIo 268+
Turn the device off( from the back button) press volume up and the flag button( third from the right) in the same time and power on the device. Keep pressed the two buttons untill a screen shows . Press ok and then another ok. Then restart the device. This will do it
Jan 07, 2009 | Mitac Mio 268 Car GPS Receiver
Samsung Jet S8000  Cell Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
