Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Laser 72 when burning on high i can smell fuel and it smells up the whole house. while running and what to do about the smell while the fan is on and working fine.
  • ronson Jan 15, 2008
    Mine is a Laser 73 and strong odors fill the house when heater is on med. or high heating modes. It smells more like exhaust fumes than unburned fuel. checked all connections, lines, pipes, and filters. I didn't exactly understand solution #1
  • dewebb Mar 07, 2009
    I have the smell of fuel strongly from time to time with my Laser 72.. It's definately NOT exhaust... I get THAT when the wind blows into the exhaust pipe from the south.. This is like diesel fumes that permeate the whole house when it's happening. Doesn't happen all the time.. makes me think I have a small leak somewhere inside the unit where the fuel can evaporate over time.. Someone else told me maybe it's a buildup of soot or dirt on the line nozzle that dumps fuel into the main burner.. said to take it off.. and clean the end.. and that should solve the problem. Will try that solution today...
  • 57 Answers
I had this problem. I discovered spilled fuel had accumulated in the back of the heater along the bottom of the wall. A pain to clean up because you have to take the top and sides off, then you can be sly and just remove the screws at the bottom of the back wall, and maybe one or two screws up the back middle so you can pull the wall away from the bottom edge and clean up the silled fuel.
I was pretty tiffed to find this because it happened when it was serviced. Grrrr.
Posted on Jan 26, 2008
    Master:
  • 619 Answers
Check the tank open/ if you fume detector you may detect it sometime some leak within distrbution hose clamp expanded hoses can be cause of leak.
Posted on Jan 08, 2008
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Laser 72
Your manufacturer, Toyotomiusa, recommends that you tighten all the joints on the fuel line. Your owner's manual CLICK HERE contains detailed drawings showing the location of all parts, including the fuel injector. Your unit will need to be serviced by a qualified technician if you have tightened the connectors and still smell kerosene or find wet spots under your heater. It should not leak or smell of kerosene. If you're smelling kerosene, you should not operate the unit, because the leak may cause a fire.
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater:...
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
My air conditioner on my 1999 kia sportage smell like smoking and like burning went turn on
do you turn on fan when using a/c ! if so heres a few causes-- burning smell in car, blower motor is going bad, or resistor is burning up.the resistor controls the fan speeds. good-day !
The burning smell could be due to gas leakage in the engine compartment. The gas smell is being sucked into the fresh air intake of the air conditioner. It can be avoided by checking either fuel pressure regulator or fuel injector.
Sep 24, 2011 | Kia Sportage Cars & Trucks
I have just lit a coal fire for the first time in the living room, all is OK ecept when I went into the bedroom (2 floors above) I could smell smoke quite badly Any advice?
The chimney needs to be 3 feet taller than the highest point of the house . If you are running the clothes dryer, bathroom vent fan, or exaust hood in kitchen it makes a vacum in the house that can draw smoke into the house down the chimmney . I think when you burn wood or coal in a house it is pretty hard not to be able to smell it. Our house and clothes do not smell like smoke any more since we stopped burning wood.
Feb 02, 2011 | Heating & Cooling
Burning smell from motor when I plug cord in outlet. Also, blades do not turn.
if the smell is foul smelling the windings in the armature of the motor are shorted out against the metal housing of this armature. You need a new motor or replace the fan
Apr 08, 2010 | Lakewood High-Velocity Fan
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Peg Perego John Deere Gator has burning smell
It sounds like it may need a new wire assembly.
I bought mine here
http://www.shopjandl.com/
and they also helped me with my other ride on toys.
My grand children have several of these so we are always getting parts for them.
hope this helps
Jul 16, 2009 | Peg Perego John Deere Gator HPX Ride on...
Chemical smell coming from fan?
I have installed hundreds of fans in homes and businesses. The only smell complaint I have encountered was from a fan that came with rubber band like gaskets around the light shades. I guess these were intended to cushion the glass where the mounting screws contacted it. When the lights heated up the glass, a hot rubber smell became very strong. We tried smaller bulbs with no help. The solution was to throw away the rubber bands and attach the glass with the screws directly like all the other brands. Since then, I have always thrown the rubber gaskets away if they come in the kit.
Jun 18, 2008 | Hunter 21617 Palermo Brushed Nickel...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
388 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
