Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
The monitor keeps shutting off after i turn it on
    Master:
    Sergeant:
  • 460 Answers
Your monitor PS card has been faulty. you can repaired it from service center.
Posted on Nov 13, 2009
DS-1900S DoubleSight Displays keep shutting off
Sometime the cross-talk of signals causes this. Separate the wiring behind the computer. No touching, no problems.
Mar 06, 2014 | DoubleSight Displays - DoubleSight...
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
My lcd monitor keeps shutting off
your power supply probably has bad capacitors and they need to be replaced
Jan 10, 2010 | Acer X221WSD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp FX 70 monitor keeps shutting off
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Feb 14, 2009 | HP Pavilion FX70 Monitor
Monitor (viewsonic e70fb) keeps shutting itself off
the screen has begun vibrating and is very hard to read.
it sounds me that there is some sparking in power supply or high voltage section (FLYBACK) due to loose contact,
your problem of  shut off, I would turn it back on and it would stay on
.might be also due to that only.
please call tech if you are not a tech person.
it is not a major one & simple to fix.
good luck.
Oct 11, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
359 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
