Question about Turboair Turbo Air 40" Floral Case TOM-40B
I need a termostat for Turbo air TOM-4013 - Turboair Turbo Air 40" Floral Case TOM-40B
  • 2,237 Answers
Www. partselect.com
Posted on Nov 13, 2009
I have a honeywel t8002c termostat w heat already connected. The ac unit needs to b reconnected. Two wires for the ac to b connected. Was connected before but moved the termostat thus winter and didnt...
You need to connect to the Y terminal and the C terminal for A/C unit. The best was is to connect thermostat to furnace and then connect the two wires to A/C off furnace circuit board at Y and C terminal.
May 13, 2011 | Honeywell Heating & Cooling
1kz te automatic turbo engine overheat
Sounds like you have the classic cracked cylinder head the 1KZ TE motors are renowned for
Aug 05, 2009 | 1995 Toyota 4Runner
Whats the make-up of the r?otating assembly
It all depends on how much pressure you intend to run the turbo or supercharger at. If you won't exceed around 12 psi, you can keep the engine stock without damaging or shortening the engine life too much. If you wanna go bigger than that, you might need to upgrade the pistons and crank. And as for compression, either a charger or turbo will do the same thing as far as the compression is concerned, so if compression is too high for a turbo, it's too high for a charger also. And I'd start checking more for upgrading the fuel system than the engine assembly parts, cause you will need more fuel in the engine to compensate for more air coming in due to turbo or charger way before you need to strengthen the engine for the extra power.
Jul 08, 2009 | 1999 Ford Mustang Cobra
I have a Datsun/Nissan 280ZX non-turbo (Not a 210)
Have the thermostat tested first. You can do that by observing if the fan turns on when the fan exceeds your normal running temperature. You may want to check the radiator cap it may be worn out that some steam may come out through it causing temperature to increase in the process.
Jul 05, 2009 | 2005 Datsun 210
My home heaer is out of service..........
is you unit a heat pump if so it may have tripped off on high head pressure . check your filter and if its dirty replace it then go up on the roof and look for a red button and if it has it press it and the unit should come back on.
Jan 06, 2009 | Water Heaters
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Turboair Turbo Air 40" Floral Case TOM-40B Logo
103 people viewed this question
Top Turboair Refrigerators Experts
David Jewell
jasbo
jasbo
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
