Question about Microsoft Xbox 360 Console
What wire do i need to connect xbox to computer, or is it better to connect to internet box with ethernet cable? inernet box in living room, xbox about 15 metres away in kids room.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 111 Answers
Go with the ethernet cable and add your Xbox to your computer as a media extender in your "Network" settings.
Posted on Nov 16, 2009
Ok, my router is way in the other room and I want to connect my Xbox 360 to the router for XBOX LIVE. The thing is, is that I can't find a way to get something to extend the wire that's connecting to both;...
There are several solutions to your problem .
1. Run Ethernet Cable from an attic & drop either end down in the walls of the two rooms . Hardwiring is always going to give you the fastest , most stable connection .
2. Purchase a set of Power Over Ethernet Modules , you then plug your ethernet cable into your Xbox 360 on one end & the Power Over Ethernet Adapter on the other end , then plug the " POE " Adapter into a standard electrical socket . You will do the exact same thing on the other end with the Router this time . It should connect just as if you ran a single ethernet cable between the 2 devices .
3. You can use a laptop or desktop pc with a Wifi connection & Ethernet port to Wifi Tether / Share your Internet Connection . Just do a google search on Wifi Tether Xbox 360 or check out some of the videos at
http://www.google.com/search?q=wifi+tether+xbox+360&hl=en&prmd=ivnsfd&source=univ&tbm=vid&tbo=u&sa=X&ei=l_SoTfyFI4-usAOT1PX5DA&ved=0CHQQqwQ
Apr 16, 2011 | Microsoft Xbox 360 Console
I need to know how i can get xbox live with the ethernet cable
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection.
2. Turn on your xbox 360 and go to the xbox live tab.
3. Go wher it says Join and follow instructions.
You can put your credit card info. or buy a prepaid xbox live card
May 28, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
My pc has room for one ethernet cable and its already taken to a router box. i have no idea what its for but now there seems to be nowhere to hook up my 360. i want to hook up for xbox live and netflix....
Simply put
You need to plug your xBox 360 into the Router not the PC.
The Router should have more than one ethernet slot. (That is what is generally meant by the term Router).
Therefore:
1. Plug one end of the Ethernet cable into your xBox 360.
2. Plug the other end of the Ethernet cable into an available slot on the Router.
If your Router is constantly connected to the Internet then this should solve the problem. If it is not, then connect to the Internet via your PC and then when the internet is on the xBox should find it.
Hope this helps. Regards,
Feb 09, 2010 | Microsoft Video Game Consoles & Games
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Dial-up 360 to laptop
plug xbox in via ethernet cable, then open network connections. choose the internet connection and the wired network connection. once both highlighted right click and choose bridge connections. then u might have to change settings on xbox but u may be ok.
Aug 08, 2008 | Microsoft Xbox 360 Console
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Internet & xbox live sametime Netgear 8-port 10-base-t Ethernet Hub en108
Does the xbox work when connected directly to the internet (not through the hub)? If so, there may be some kind of conflict related to sharing your internet connection between the PC and xbox, and I'd reccommend getting a router instead of a hub.
Feb 20, 2008 | NetGear ProSafe DS104 10-Port Ethernet Hub...
Xbox to compter
Path #1:
if you want to play online, with other people i am assuming? then what you would want is xbox live. you do have to setup a stable internet connection in order to connect to the internet*. and also you do have to pay a membership fee in order to stay in xbox live.
* and if you want to connect xbox live, you need a cable or dsl connection, either you need an ethernet cable or a pre-tuned wireless usb that is made only for the xbox 360. and also, you would need a cable/dsl company that is accepted by xbox live. and then go to the xbox 360 dashboard, then, click "join membership",
Path #2:
setup an ethernet connection either directly, or with a router/hub, then go the system settings, and click, "computers" and then click connect. but this path way is only to create a connection to the computer.
Jan 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
