Question about Parks Optical Briggs And Stratton Engine Intek 10.5hp Lawn Mower
No spark - Parks Optical Briggs And Stratton Engine Intek 10.5hp Lawn Mower
  • 486 Answers
Specifics on engine needed, brand, model, type, code, serial numbers. Thanks, rwvanlue
try the things below to see if they help
1) How have you determined that there is no spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Not getting spark out of spark plugs
For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
May 28, 2012 | 1996 Ford Contour
Wont start no spark on spark plug
Car has no spark?
This will help.
Thanks.
May 24, 2012 | 1990 BMW 525i
CAN'T START CAR AFTER SMALL REPAIRS NO SPARK
Car has no spark?
This will help.
Thanks.
May 15, 2012 | 1992 Acura Legend
1994 mitsubishi expo not getting a spark to spark plugs
Car has no spark?
This will help.
Thanks.
May 11, 2012 | 1994 Mitsubishi Expo
Nosparkfromcoil
Car has no spark?
This will help.
Thanks.
Mar 06, 2012 | 1992 Honda Accord
1986 buick 3.0 engine stalls, no spark then after 10 min. there is spark
Car has no spark?
This will help.
Thanks.
Mar 03, 2012 | 1986 Buick LeSabre
No fire to the spark plugs
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
Feb 23, 2012 | 1993 Honda Accord
Parks Optical Briggs And Stratton Engine Intek 10.5hp Lawn Mower Logo
169 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
