Question about Kyocera Copystar CS-1820 Black and White Copier
We have a red line thru our scans? I have cleaned everything it says to clean?
  • 145 Answers
Red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Posted on Nov 14, 2009
When I use the printer to scan via the document feeder, I get two parrallel lines down the right hand side of each page of the pdf. I've cleaned the glass and everything else but still get the lines....
Open the scanner cover and you will see two glasses. One long and thin and the other larger than an A4 sheet of paper. The long thin glass is used to scan thru the adf and the larger glass is for flatbed scanning.
As your lines are from the adf scanning, you will see tippex on the long thin glass. just clean it off and all will be well. Clean the flatbed glass as well while you are doing the job on the adf glass.
Sep 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
How do I get rid of a vertical black line on my feeder-fed copies and scans?
when using a document feeder to feed originals thru your machine the originals are "scanned" by a thin glass. this glass can get dirty with whiteout or other things. Open up the document feeder and clean the glass with a cloth with a small bit of rubbing alcohol on it. Use a flashlight to look at this glass because tiny spots can cause lines on your copies. Good luck.
Mar 01, 2011 | HP Office Equipment & Supplies
When , I scan using the top loader, a red line appears
I would say to clean the glass where the scanner bulb is parked. Just lift up the cover and clean the glass. if you look close you could see a red mark on the glass. Steven
Feb 04, 2010 | HP LaserJet CM1312 All-In-One Printer
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Line on ADF feeder
Clean the narrow piece of glass inside the machine next to the large glass.
Oct 21, 2008 | Canon imageCLASS D860 All-In-One Laser...
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Lines on scanned images
if the lense has dust on it how do i clean
Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
170 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
