Question about Brother DCP-8060 All-In-One Laser Printer
Brother DCP-8060. It's displaying a message "No Paper" and "reload paper in tray 1", but the paper is in the tray. Still, it says "No paper", so does not print anything.
  • Brother Master
  • 1,692 Answers
Hi Fliliya, The link below is a FREE 116 page user manual for a brother DCP-8060all in one, I hope it helps.......CHEERS..
https://www.encompassparts.com/shop/model_research_docs/?file=/BRO/om/DCP8060.pdf
Posted on Apr 17, 2016
Mix-it-up
  • 832 Answers
SOURCE: i have a brother copy/fax/print
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
Posted on May 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Brother dcp 8060 reinstall paper tray error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
  • 93 Answers
SOURCE: Printer will not print message No Paper Fed yet paper in tray
Hello Phillip_hell !!
Thank you for writing to fixya.com.
Here's a Knowledge Base article on the Brother's website for this problem. Just follow the instructions carefully & I am sure enough you'll not be disappointed. Here's the link:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000090/faq002490_000.html?reg=us&c=us&lang=en&prod=dcp330c_all
This article explains step by step to fix this issue.
Hope this would be helpful & remember to mark the thread if you find this helpful.
Warm Regard's
Anurag Shukla
Posted on Sep 03, 2009
SOURCE: Brother MFC-9840CDW says no paper when trying to
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
Posted on Nov 30, 2010
CAN I PRINT LABELS ON A DCP8060
Yes. Just be sure to place them correctly in either the paper tray or in the Manual feed Slot.
Feb 25, 2016 | Brother DCP-8060 Laser Printer
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
My machine is not working with tray, it display jammed paper
machine tray will be clean .Printer fuser parts clean.plz tell me my cell no. 08273174139 vishal
Dec 07, 2011 | Brother DCP-7030 Digital All-in-One Laser...
When printing on my DCP-8080DN, I am getting a thick black line
Try this:
Clean the inside of the machine and the corona wire in the drum. If this does not solve your issue, replace the drum. Also, the paper tray ground terminal in the machine body may be dirty.Clean the contact with a dry cloth.
Jun 17, 2011 | Brother DCP-8060 Laser Printer
How to replace paper? show pictures!
theres a paper tray at the bottom, you pull it out and put the paper in.
(the gray section at the bottom)
hope that helps :)
Jake
Feb 18, 2010 | Brother DCP-8060 All-In-One Laser Printer
I have a paper jam in Tray 1 where is Tray 1
Hi Yor tray 1 is the first tray where you put your A4 paper in have look to see if the paper not to tight and maybe you can take your tray right out then look at where the rollers take the paper up it may be in there.
I have put a PDF files on my website for you to download.
Brother-DCP-9040CN-DCP-9045CDN-MFC-9440-MFC-9840.PDF
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and save it to your PC.
Click LINK= http://www.4all2sell.com/pdf/Brother-DCP-9040CN-DCP-9045CDN-MFC-9440-MFC-9840.PDF
You need a adobe reader to see this file If you not got a pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 08, 2010 | Brother MFC-9840CDW Laser Printer
DCP 8065DN
please print option paper source setup mp tray and setup page size then solve your problem
mp tray is copier front side open it and insert paper or print source lower casset
i pray you wiil success
Sep 03, 2009 | Brother DCP-8065DN Black and White Copier
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Jan 05, 2009 | Brother Multi-Function Center® DCP-8060...
Brother DCP-8060 All-In-One Laser Printer Logo
373 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
