Question about Cell Phones
Time settingsare set in military time but i need it in normal time
How do i get my clock off military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem
Nov 06, 2016 | Audio Players & Recorders
Turn off military time
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
Apr 06, 2013 | Brookstone LEGO Ninjago Kai Mini-figure...
My bose just started using military time in place of the P.M. how can I get this back to using normal time?
It's in the manual...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Jul 05, 2011 | Bose Wave Radio
How do I set the time? It is on military time and since it was my mom's, and she passed away, I do not have the manual. I would appreciate knowing how to get the time regulated to normal time and not...
Hello Donna.... To set AM/PM (12 hour) or Military (24 hour) time:
1. Press the On/Off button once to turn your Wave radio off.
2. Press and hold Clock Set,
3. and then press On/Off to switch between
Here is a free downloadable manual link: http://docs.google.com/viewer?a=v&q=cache:hq_f0HoUsrYJ:products.bose.com/pdf/customer_service/owners/og_wrv5.pdf+bose+wave+radio+manual&hl=en&gl=us&pid=bl&srcid=ADGEESgxjUcI-s84YEg1C5bRcTQ4NYwYTUQO8rYGaGlDmznSQZ7JNZbfeTdyIvdo-UePSkoIefe90mepH9kqqKF01TEdcOH9_Y4eUOOX2Ft1DHL-W1j6VHfyn0HXlfEdrlPMCV0HU37u&sig=AHIEtbQrpVKLuROminuPn1o9s4qlwPpw-A
Look on page 18 for more info on switching between military time and normal.
Joe
Thanks for choosing Fixya!
Dec 30, 2010 | Bose Wave Radio
Time is on military time. want to switch to
If you have the manual then it should explain how to change from "24" to "12" display.
If you haven't got the manual then some experimenting my find the solution to your problem. One of the buttons should cycle through the settings menu and in there should be an option to set the display.
Dec 19, 2009 | Timex 1440 53591 Sports Quotient...
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
Emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Mar 11, 2008 | Timex 1440 Nylon watch
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
