Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
My new Bosch Nexxt 500 series washer is less than 30 days old. I can turn it on any program and I can hear it initially fill with water, but it does not spin to wash or rinse. It does not have any error messages and I am not sure what to do.
  • Bosch Master
  • 3,463 Answers
As your washer is less than 30 days old, I strongly recommend that you contact the company you purchased it from, and ask them to change it for you, under the sale of goods act, you have the right to insist upon a replacement washer.
However, before you do that, double check your handbook, and make sure it is nothing you have done wrong.
Try switching it off, and then try again to use it.
Please leave feedback.
Thankyou
Posted on Nov 13, 2009
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I had E13 code, followed MacMarkus guides, cleaned the space now no water come to the drum. My Nexxt 500plua is less than 2 year old, but out of warranty. Thank for your help. Le
You might want to install a water filter for your Bosch Axxis washer faucet so you can prevent this from happening again. Remove any sediments or dirt obstructing the flow of water in the hose. Pull the sensor that is located n the inlet valve and check inside to see if anything is trapped. If you are using corrosive water, just replace the sensor. If it still works just fine, then cleaning it will suffice.
Dec 04, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My 2.5 year old Bosch Nexxtg 500 WFMC3301/UC washing machine fills then drains. Does not complete wash cycle. If I leave off for a couple of days it will fill then drum turns for awhile, but will not...
sounds like heater fault this will terminate program if no heat detected after a short time, hard water will make it worse unless you use a water softening agent.2.5 years for this is not unusual.
Nov 28, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch machine is filling with water when not on! is this a valve or water intake part problem?
Not alwys fill valve fault.. make sure not draining back from sink back into mach,,if yes put drain hose higher to cure...
Sep 08, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Washer flashing E:
John-I have the same problem. I called service, they told me to unplug it (or turn off the breaker) for 30 mins, then turn back on. That should reset it. However, for me, it didn't do a thing. He said if that didn't work it's time for a service call.
Jul 03, 2009 | Bosch Nexxt 500 Plus WFMC530SUC
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
May 25, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
221 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
