Question about Candy CNW136 Front Load Washer/Dryer
CNW136 Dryer not working !!
My Candy CNW136 has suddenly stopped drying the clothes. Wash cycle seems fine. I cleaned it out to make sure the condensor was not clogged but still no joy. Please help.
  • 1 more comment
  • mrdjc Feb 17, 2008
    Thanks D-Mac
    Found the safety stat and clicked it but still no heat. I take it that it now need a new heater?
  • redbull2k7 Aug 01, 2008
    i have the same problem ,where too is the condenser filter ?
  • kabates63 Jan 26, 2009
    washer ok, dyer blows cold air and drum turns but no heat. Why? help
  • 46 Answers
Lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Posted on Feb 07, 2008
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
Jul 15, 2009 | Candy CNW136 Front Load Washer/Dryer
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
May 23, 2009 | Candy CNW136 Front Load Washer/Dryer
Water not pumping out
I had a similar problem which I solved by cleaning the filter which had a blockage. It then worked fine. Hope this helps
Jamie B
Aug 14, 2008 | Candy CNW136 Front Load Washer/Dryer
Dryer not working properly
its likely to be the condenser unit in the rear of the machine full with lint check for a large clear / opaque unit with pipes connected and make sure it is clear
Jun 19, 2008 | Equator EZ 3612 CEE Front Load...
Washer/dryer stops mid cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Mar 02, 2008 | Candy CNW136 Front Load Washer/Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy CNW136 Front Load Washer/Dryer Logo
775 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
