Question about Technics SCEH790 CD Shelf System
Hi I have speakers SB-DV290d can I plug them into my existing system or do I need anything else?
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
Is it possible to still use my old 90w/4ohm surround speakers on a blue-ray system nornaly using 125watt/3ohm surround spks.without causing any damage..Therefore If this is un-advisable, thus as I...
It would be helpful to understand what electronics we're building a system around.
Next time type carefully and provide exact make/model numbers as typographical errors in a model number will send us careening down the wrong path.
I'll assume you're talking about Panasonic models. I would highly advise AGAINST mixing HTS speakers with any make or model they're not designed for. If proprietary connectors instead of bare speaker wires are present that's a huge warning sign.
Take those wattage specs with a huge grain of salt as they're strictly for show and have no grounding in reality at normal acceptable distortion levels.
4-ohm (or less) speakers will present a challenging load to anything not designed for that low an impedance.
You're treading in unknown territory where creativity might yield poor results at best and equipment destruction or worse.
Jan 17, 2011 | Panasonic Audio Players & Recorders
Speaker enclosures for SB-DV290
Yes technics is panasonic so call this number and tell them you are aking about the technics separates system. the number is for UK 08705 357357
Sep 30, 2008 | Technics SCEH790 CD Shelf System
PANASONIC SURROUND SOUND SB-WA3300
May be wrong number. SB-WA330 is name of speakers and search http://safemanuals.com/ to give you the right manual
Samuel
Aug 18, 2008 | Panasonic Home Theater System System
Panasonic SB-AK57 cable fix
Hi Raj,
you,ll find that you have 2 sets of cables.
you need to use a multi-meter tester, to find a continuity circuit of the speaker. If you don,t have A Meter try the red as + and every other 1 individually as A -.
If that does,nt work try the black with any individual.
Hope this helps, solve your Problem.
Mike.
May 06, 2008 | Philips FW-R7 CD Shelf System
NO DISC message
I assume that problem is dirt on laser lenses. If you don’t get any result after this, than you can replace receiver with new one. If you want to use your existing speakers with new receiver with integrated amplifier, you must pay attention on wattage, to be same like old one (i.e. 100W), and also resistance (i.e. 4 ohm). If it’s same like old receiver, you should have no problem. Good luck.
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
May 01, 2008 | Audio Players & Recorders
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
Technics SCEH790 CD Shelf System Logo
121 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
