Question about ASUS Intel 440BX Chipset CUBX-L Motherboard
How much big HDD can i connect to my ASUS-CUBX-L motherboard?
I have an ASUS-CUBX-L motherboard and i am currently planning to upgrade my hard disk, since my old HDD crashed. I doubt whether this mother board supports the 160 GB and 320 GB PATA IDEs (Seagate or Western Digital) available now. Can some one confirm me on this. If these hard disks are not compatible please let me know which is the highest one i can use. My busted hard disk was a Maxtor 80GB.
Thanks
Antony
  • Antony_003 Jan 09, 2008
    Thanks Nitrotrike for your suggestion. I think it should work. But Can you please help me with this. Please let me know how i can get the BIOS update utility and also where in the net i can find the latest BIOS updates that can be downloaded.
  • 589 Answers
The size of the drive that will be detected can vary on a number of things: bios version, and OS.
They will both "physically" work, but the full capacity may not be "seen".
The 160 should work fine, but the 320 may only "show" as a 250 or 300.
My best advice is to flash the bios to the latest, and start with the 160. Install your OS, and connect the 320 as a slave after the OS install, and check its properties.
Posted on Jan 08, 2008
  • brian c
    brian c Jan 09, 2008
    The last bios was dated 8/27/2002, version 1008.004
    When you go to this site, put in 'CUBX-L' in the box in the upper left.
    The bios file is under "bios"
    The flash utility is under "bios-utilities"
    Let me know if you need any more help.
    http://support.asus.com/download/downloa...
I am using a compaq presario SR 1435IL. I want to know whether i can use two internal hard disks and also upto what capacity is it supported I already have a 320 GB western digital hard disk. Does it...
hi, i believed there is no possible way of putting 2 internal HDD in 1 laptop, seems the area of the existing HDD inside is already limited and also crowded of some other parts...and its not designed for 2 HDD either. the best way for me to advice is upgrade the existing HDD to higher capacity from the existing " GB " to " T " or add up a big capacity 2.5 " pocket size external HDD.
Aug 26, 2011 | HP Compaq Motherboard
Helo, i want to upgrade memory on my ASUS CUBX-L motherboard. Manual says it recive max 4 x 256 MB of SDRAM. Is it possible to put 512 MB or bigger RAM modules?
yes you can put 512 mb of ram even 2 of it because the capacity of your board is up to 1024 mb of ram but make sure that it is an sdram and it has the same specification on whar is your manual indicate besides on the ram size.
Oct 14, 2010 | ASUS Intel 440BX Chipset CUBX-L...
CANT CONNECT A 1TB SEAGATE 7200RPM HDD. oRIGINAL BIOS ON MOTHERBOARD
The BIOS may not be able to support a hard drive of such a large capacity. Check the motherboard manufacture's WEB site to see what size hard disk the BIOS can support. There maybe a BIOS upgrade that will allow the motherboard to support larger hard disk capacity.
Oct 02, 2009 | ASUS A7V400-MX Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Query regarding maximum capacity of motherboard support for a hard disk
your cpu does not have much to do with the hdd you may be getting...
technically you should have no problem by getting the largest hdd you can afford. what you may want to take into consideration besides your budget is:
what os you're using.. dos, win9x, xp, vista?
a. if you have dos the smaller you can get probably the better as you may not be able to create a large partition. (chances are you may not get anything new smaller than 40 gigs.. and that would be a big waste of money and hard drive room)
b. if you have win9x, your probably using fat32 for your filesystem meaning you may not be able to go above 32 gig when creating your partition and formating your drive.
c. if your using win xp or vista... and your planning on using NTFS when partitioning the drive instead of FAT32...(as you should unless your operating system is on a FAT32 partition) you can go for the largest hdd you can afford.
Sep 21, 2008 | Computers & Internet
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
Format 320 GB HDD problem
Have tou tried the mangement in windows, My computer> right click>manage, then disk management and then right click on your hard drive and then one of the options is to format. Although only 127gb will show and the rest should show as a seperate partition, do the same with this to implement it. If no other partition shows you may have to upgrade your motherboard bios to suport large capacity disks.
Apr 23, 2007 | ASUS P4PE/L (ASU49J) Motherboard
CPU Upgrade on ASUS CUBX
no a P4 uses a different ZIF socket type the the one on your motherboard. You can only use a pentium 3, so if you are looking for more speed upgrade your memory instead.
Apr 17, 2007 | ASUS Intel 440BX Chipset CUBX-L...
ASUS Intel 440BX Chipset CUBX-L Motherboard Logo
167 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
