Question about Samsung SGH-E900 Cellular Phone
My words samsung g600 does not remember my words when i add them writing a text message
  • Anonymous Jun 08, 2008
    This is the 3rd G600 i've had & when i add a word within hours it has gone, i have returnedd the last 2 phones but was hoping there was a solution 2 this problem.
U might have selected the message writing in the number format
plz change it to the alphabet form.
if resolved notify me on
jala_sudhir@rediffmail.com
Posted on Feb 01, 2008
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
I am not able to send text messages from samsung sgh g600. What should I do?? This problem occurred recently.
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Oct 05, 2010 | Samsung SGH-G600 Cellular Phone
Turn off predictive texting
try this:
While starting a text message, hit the menu key and see if it brings you to a text entry menu ... Select alpha, numeric, word, ... you usually can switch around while writing the message via the menu.
Jun 03, 2009 | Samsung J700 Cellular Phone
Not receiving or sending mulitimedia messages
its becuase you dont have the required settings from your network providor to send MMS,
all you need to do is go onto there website i.e vodafone and search for the settings page then put your mobile number in the box and press send when you get the settings you save or install them, or if your not technically minded you can give a quick call to your network and they will send them in a text message for you.
Jan 26, 2009 | Samsung SGH-G600 Cellular Phone
Text message tone
Go to menu,Go to settings,Go to sounds settings,Go to alert sounds,now pick the alert you want to get a tone for. It should ask if you want tone or vibrate, hit tone and scrollt o the tone you want to assign to it. Hope this helps.
Jan 13, 2009 | Samsung SGH-G600 Cellular Phone
Add word in Uppercase only
hold star button down to change from caps to small
Nov 11, 2008 | Samsung SGH-G600 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
52 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
