Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
The solution won't come out - Bissell 1400 Little Green Pro Canister Steam Vacuum
I didn't have the solution tank in proberly, it looked like it was but then I pressed down on it and I heard it snap in place.
Posted on Nov 14, 2009
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
Neato vacumm won't turn on
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Apr 17, 2013 | Neato Vacuums
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
The vacuum keeps falling over and won't stand upright. The vacuum won't **** from the bottom, only from the hose in the handle.
No Vacuum will work for more than a few weeks
if you don't own an air compressor & blow them out
after every 2 or 3 uses
May 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
91 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
