Question about Nintendo Wii Console
Won,t connect to the internet keep comeing up with errors all the time
  • 864 Answers
I will be glad to assist you with this. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you need further assistance please let me know and i will be glad to assist you. Thanks - Midwest-tek
Posted on Aug 27, 2010
Connection problem on vigo tablet
Not a solution, but... we could not connect to Vodafone, as the Vigo was not compatable with our Vodafone supplied Huawai modem!!!!!
Dec 27, 2012 | Tablets & eReaders
Error code: 52132 i can't get on netflix it won't hook up to my wireless router. i've searched for new wireless connection but keep coming up with the same problem.
Check the connections to your wireless router:
Manually change your Wii console's DNS settings. To do this, follow these steps:
Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
Select "No," and choose "Advanced Settings."
Click into the "Primary DNS" field and enter: 8.8.8.8
Click into the "Secondary DNS" field and enter: 8.8.4.4
Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
Select "Confirm," and then "Save."
Select "OK" to start the connection test. Once the test finishes, try to download the update again.
for more help visit CBR Tech Solutions
Aug 21, 2011 | Nintendo Wii Console
Every time I try to connect to the internet it my DS keeps 'No compatible access point in range. Check your connection settings and try again. For help visit suppoert.nintendo.com Error code:...
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Jun 18, 2011 | Nintendo DS Lite Console
80028E02 (this error keeps coming on my ps3 and it doesnt make me sign in online! please help
ps3 error 80028e02 can be caused by different source of networkshowcase270.jpgblockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online.
If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
Internet Explorer cannot display the webpage
If the error comes only with a particular website then it is possible the website is not operating or has closed down.
But if the error is coming with all websites then your internet connection may be faulty. Hard to provide much more help without details of your internet connection type, the operating system on your laptop, etc.
Jul 17, 2010 | Computers & Internet
Can not log into my yahoo messenger
try to check your internet connection if connected to
the internet. please check also your username name and your password and the caps lock button is activated..
Oct 08, 2009 | Yahoo Messenger
I can't connect to the internet via my router
i have bought a dlink wireless router.hooked up to desktop computer ;with no problem. but can;t get a signal for my laptop (toshibs 2000 professional) can you help me what am i doing wrong ;do i need to buy something for the laptop.
Jun 07, 2009 | Dell Wireless 2350 Router
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
Psp
Welcome to Fixya.Give me more details about the problem.So i can help u in a well manner
Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
