Question about Black & Decker Garden
The vac function stopped.
While using the blower vac to collect leaves, the vac function stopped. and now the blower vac will run, but just is blowing very weakly. What I want is for it to vac. is there an easy fix or way to troubleshoot this?
  • 486 Answers
Somewhere in the tube or impellor area, it is plugged with a piece of debris that is clogging the flow of air to the bag or outlet.
Posted on Nov 13, 2009
Engine will not go to high speed fuel oil mist blows out .checked spark arrestor ,muffler,exaust ports.
If the mix is blowing out the muffler than it is flooded either due to improperly adjusted carb, stiff diaghrams in the carb or weak spark. Weak spark could be a bad plug, failing ignition module, or spark ouit of time ( sheared flywheel key).
Bad fuel will also cause this symptom.
Oct 25, 2012 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Tip
Clean your dryer at least once a year
doesn't matter what kind of dryer you have,you should clean it out or have someone clean it out at least once a year more so if it's gas so you don't have a fire on your hands,unplug dryer, go outside and make sure nothing is blocking the air flow and outside flapper is blowing fully open and clean out the vent line, disconnect vent line from the back of dryer and blow it out with a leaf blower if it's a long run just stick the leaf blower right in the vent line that you disconnected from the back of dryer and blow out to the outside vent hood,vac out the inside of dryer and clean out the duct where the lint filter slides into,a shop vac works great because the other end of it has a blower on it,blow the lint off the motor and blow the lint that's in the back of dryer so the lint comes to the front so you don't have to remove the drum and don't run the dryer or any other appliance if you are leaving the house
on Dec 02, 2009 | Dryers
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
I've had mine for about a half a year now. and it keeps turning on for a little tiny bit then turns right back off. and it just stopped working like that randomely i didn't do anything to it?
it sound's like it's over heating, try to blow some dustout of it, i use my shop vac in the blower mode, the inside of the moniter collects dust, and it does not vent properly,,, good luck
Dec 21, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Troy-bilt gas blower/vac stopped and pull cord won't come out
NOPE You can buy new cheaper than have this one repaired, Also I don't recommend using these for a vac on leaves. Leaves are very very dirty and these blower vacs usually dont last long when used as a vac. The seize problem was from an improper fuel mix. THE next one you getone use a little more oil, than says in the owners manual. Like if it says 50/1<<>> mix 40/1 more oil will just foul the plug and oil the muffler,but you will not have a seizure problem. I have never had a problem with a 40/1 mix .
Oct 21, 2009 | Troy Bilt 31cc Quickshift Blowervac, Model...
A/C blower stops blowing air on acceleration
you have a vaccum leak some where on the engine start the car up open the hood a listen you may be able to the leak it will make a hissing noise
May 29, 2009 | 2000 Ford Taurus
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
237 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
