Question about Panasonic DMC-ZS1 Digital Camera
CANT WRITE TO UNLOCKED SD CARD I've tried repeatedly to write files to various sd memory cards in my ZS1 and it always gives me the message that the card is locked and can't be written. The cards are UNlocked physically, and I have no trouble writing to them when they are inside other cameras (Canon & Fuji). Is this a defect of the Panasonic or is it fixable?
  • Panasonic Master
  • 3,289 Answers
Are you sure that the lock / unlock tab isn't getting moved to the lock position when inserted AND then moved back to the unlock position when removed? Stranger things have happened.
Some cards have lock / unlock tabs that are so flimsy that it seems that you can "will" them to move. Try placing a small amount of tape in such a way that the tab is prevented from moving (if you never use the lock feature like me, you could use a drop of glue instead of tape). You might have to remove some excess tape in order to slip it back into the camera if the slot is "tight".
If still unable to write to the card in the camera, but can when in a card reader - the problem could be in the camera. The next logical step would be to try a different card. If the new card fails in the camera but not the card reader; the camera probably needs to be sent out for repair.
I hope this helps - and good luck!
Posted on Nov 13, 2009
My Samsung ES30 camera gives me the DCF Full error message.I tried other solutions ,such as formatting the memory cardd,I even tried a new memory card.Still the message comeup.Who know what to do?I am in...
The manual says: the files names does not match the DCF format. Transfer the files on the card to your computer and format the card.
You tried to format and it did not work. Sure the card is not locked? The lock switch should be up, so the card is unlocked an you must be able to format te card and you should be able to write files to the memory card.
Although the camera is compatible with SCHC I wonder if you did not put in a very big card. Perhaps your camera cant work with 8 or 16 GB. Is surely can't work with SDXC cards.
Did you try a normal SD card, and could you format that one?
Nov 02, 2013 | Samsung Cameras
How to find the file manager in sony ericsson xpera mini e10i
i need to open the memory card folder to view all the things in my memory card ( in the phone itself )
Jan 06, 2012 | Sony Ericsson XPERIA X10 Mini E10i...
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
When I go music player my nokia 7210 supernova always say " Not Enough Memory" but i have 4GB memory card, micro SD. can you help me to fix this?
It shows that the memory level of your memory card is full so either you delete some infroamtions there or go for a bigger memory like 8GB
Feb 24, 2011 | Nokia 7210
My micro sd card works with my lg shine but not my moto slvr
check your handbook for your motoz3 and find out if it will take 2gb stick then check which format is needed fat32 or ntfs.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Mar 22, 2009 | Canon PowerShot A540 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Turn off write protection on a sd micro card
If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
Apr 04, 2008 | Nokia 6288 Cellular Phone
Panasonic DMC-ZS1 Digital Camera Logo
70 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
