Question about Dell F3534 Touchpad
Touch pad doesn't work AT ALL!!!!
I have a lenovo laptop a 6530 series, and I have a logitech mouse. My touch pad is not working.
The device manager isn't helping either, it says it is installed (the driver, and up to date) yet the things still doesn't work. I tried uninstalling it and then installing it again, yet when I go under hardware and mouse, all I see are options for the logitech mouse.
Please help me out, I have no idea what to do. (p.s. I upgraded my computer from windows vista business to windows 7 thinking that, that might help too, and it didn't)
Thanks,
Kasie
    New Friend:
  • 38 Answers
Hello there, Kasie!
Hopefully I can help. On laptops, there will *usually* be a "function button" one can press to disable the touchpad in the even that one wishes to use an actual mouse instead of the touchpad. -- This would be in the interest of not accidentally triggering clicks, or mouse movement when typing, etc.
Without knowing the make and model of your laptop, I can't tell you the precise button to press to re-activate your touchpad. On most laptops, you'll need to hold down the "Fn" key (usually at the bottom left or right of the keyboard) and then find the function key (top row of keys... F1, F2, F3, F4 and so-forth)... Look at your function key row. See if there is perhaps a key with a little "drawing on it" that looks like a touchpad.. like a horizontal rectangle with 2 smaller squares under the rectangle, representing the rectangular shape of the touchpad and the two "mouse buttons" beneath it... if you find something like this, it will likely be the one you'll need to press.
However, on some laptops, the button will be just above your touchpad... you'll be able to press it, and some sort of indicator light will either light up in red to let you know it's been deactivated, or white / green to let you know that it's currently activated.
One of my laptops which is an HP has the button at the top left corner of my touchpad.. I have to "double-tap" it to deactivate / reactivate the touchpad; while my Toshiba laptop has a button directly above the touchpad which I only have to press once. -- Both laptops have an indicator light as well. The HP's "double-tap button" will turn red / dark orange to let me know that I've deactivated it... With the Toshiba laptop, there is a light just below the touchpad area which is always lit up as a "bright white light bar" when active and simply not lit up when deactivated.
I wish you the best of luck with this, and hope I've helped you!
Posted on Apr 24, 2017
bluegreenash
  • 661 Answers
SOURCE: My USB dell mouse (or any mouse) is not working.
Download updated mouse drivers from the Dell website
Posted on Nov 02, 2007
rachelgeek23
  • 155 Answers
SOURCE: Scroll doesn't work
Update the touchpad driver. Click this and follow the wizard.
Posted on Jan 02, 2009
  • 630 Answers
SOURCE: I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Posted on Jul 25, 2009
GeOrGeEtUk
  • 332 Answers
SOURCE: Touch pad scroll up and down does not work
Re-install the driver by going to the toshiba website.
Posted on Aug 13, 2009
SOURCE: laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Posted on Oct 23, 2009
My mouse pad cursor do move but it doest whant to enter if i tab on it
some touch pads have a setting that must be set to allow a tap to be interpreted as a click. Go to Start-->control panel-->mouse, and look for a setting that tells the touch pad to allow it to sense clicks on the touch pad instead of requiring a button to be pressed. If not, try updating your touch pad driver. Start, right click on computer, click on Manage, when computer management window opens, click on the device manager in the left pane. Find mice and other pointing devices in the middle pane, and click the small triangle to the left of it, to expand it. Find the one under there that stands for your touch pad, and right-click on it, and click "Update Driver software." make sure you are connected to the internet first, and let it connect to Windows Update to see if it can find a newer driver.
Jun 24, 2011 | Lenovo 3000 N200 PC Notebook
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
The mouse on my laptop doesn't work, but the external mouse plugged into the usb does. Any suggestions?
Touch Pad setup with the usb mouse installed for easy navagtion
check the device manager for mouse mouse and other devices
look for nthe touch pad label
look see if it is running ok and enabled.
Make sure it is.
Go to control panel open the mouse icon
touch pad mouse properties
Here is where the controles for external and internal mouse settings will be found.
The rest is up to you
Jun 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
Lenovo laptop touch pad not working and the curser is not moving when i touch the pad
follow these steps
1. go to control panel
2. go to mouse settings
3. check mouse settings
4. restart your computer
If still its not working please check it with lenovo tech support as there might be hardware issue .
May 04, 2010 | Lenovo 3000 Y410 Laptop
Lenovo G550 touchpad scroll bar does not work with windows 7.
Have you tried installing the drivers for the touchpad?
The link below will take you to the driver download page for your laptop, scroll down to the section for touchpad and install either the windows 7 32-bit or 64-bit drivers.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
Dec 30, 2009 | Lenovo G550-29583AU Notebook
Touch pad not working after downloading driver.
install lanch manager
device manager, rigth click your Mycomputer, manage, Device manager...
Jun 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
May 27, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Apr 10, 2009 | Lenovo 3000 N500 Notebook
Laptop's touchpad not working
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
Mar 01, 2009 | Lenovo IdeaPad Y510 Notebook
Computers & Internet Logo
220 people viewed this question
Alun Cox
