Question about Denon AVR-2807 Receiver
Good morning! Could you help me with programing my RC1030 remote from my Denon AVR2807 receiver to operate my other components? Tony
  • Denon Master
  • 19,396 Answers
Hi Tony.
Please check the links below. They have instructions and codes for your remote.
Remote Denon RC-1030.
Some info on the remote is also available on the owner manual. I posted a copy below if needed.
AVR-2807 instructions.
Posted on Nov 13, 2009
I have a 20.1 Dish remote controller. I would like to use the AUX selection to operate my Denon AV receiver. Can you help me with this?
Depending on the age of your receiver, this may be possible. Turn on the receiver. Then press and hold the Aux button until all of the mode buttons light up. Press 2 to tell the remote that the unit to be controlled is an audio receiver. Then you will need to try one of the Denon 3-digit codes. Press # and check that the mode flashes 3 times. Check if your receiver turns off. If it does, check if the other buttons work to control the receiver. Otherwise try another Denon code by starting at the press and hold the Aux button step.
If you want the remote only to control the volume, mute and power functions of the receiver, press 1 after entering the three-digit code and before pressing the # key.
The Denon device codes to try are 669 670 680 682 696
744 759 760 762 792 809 . You can find the directions for programming the Aux key on page 11-12 of the manual. The code list for audio devices starts on page 43. The manual is available from Dish here: https://www.mydish.com/filestream.ashx?ID=3025 . Usually the code list for universal remote features will not always work with devices that were released less than 6 months before the remote was programmed. Devices released after the remote was programmed are similarly not guaranteed to be supported.
I hope this helps.
Mar 29, 2017 | Denon Televison & Video
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
Feb 27, 2015 | Denon AVR-1601 Receiver
My Sony remote is RM-YD024 - I am trying to find the code for a Denon DVD player, Norm.
Here are all the codes for your Denon DVD player.
30490, 30634, 31634
Just in case you don't have the manual I also included the steps to input the codes.
Hope this helps
Follow these steps to program the remote control.
NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any type of equipment that is compatible with this remote control. For example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the INPUT button.
  3. While holding INPUT button, press the FUNCTION button for the desired component.
  4. Release both buttons.
  5. NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  8. Press the ENT button.
  9. NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
  10. Point the remote control at the component.
  11. Press the component POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, use the remote control that was provided with the equipment or purchase a universal remote control that has a learning function.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
Nov 04, 2009 | Sony Televison & Video
I have no remote and need to bring it out of
without remote u can not operate it properly go for a universal remote of reputed brands like One4All. its not costly also. U can program the remote by reading the manuals
Jul 05, 2009 | Denon AVR-600 Receiver
Want to put set of outside polk speakers to Denon avr 2807
Do you have outputs for both A and B speakers? If so you can easily hook the outside speakers to the B outputs.
Jun 16, 2009 | Denon AVR-2807 Receiver
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
System: DENON AVR 3803 The TV is connected to the receiver, so both the audio and video components are fed through the receiver, I think. The image on the TV was present, but the TV/VCR button was pushed...
THERE ARE ONLY TWO WAYS THE TV SHOULD BE CONNECTED TO THE DENON,
1. MONITOR OUT OF THE DENON TO AN INPUT ON THE TV.
2. AUDIO OUT FROM THE TV TO AN INPUT ON THE DENON.
ALL YOU DEVICES CAN BE CONNECTED TO THE DENON IF #1 CONNECTION IS USED OR ALL DEVICES CONNECTED TO THE TV IF #2 IS USED
Nov 27, 2008 | Denon AVR-3803 Receiver
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
No output from unit (denon avr2807)
El amplificador de audio IC esta dañado por eso no existe audio hay que remplazarlo.
Mar 31, 2008 | Denon AVR-2807 Receiver
Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Sep 14, 2007 | Denon AVR-987 Receiver
Denon AVR-2807 Receiver Logo
88 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
