Optoma H30 Multimedia Projector Logo
Posted on Nov 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical lines on optoma projector - Optoma H30 Multimedia Projector
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Nov 16, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
991221
Points
5072
Use "frequency" to make an adjustment. then make sure your resolution matches.
2 Related Answers
A
Anonymous
  • Posted on May 01, 2008
SOURCE: vertical line on optoma projector
I don't have a solution but I bet the connector on the projector has a bad pin.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: optoma dv10 projector has a
contact optima in california. i had to after circuitcity failed to honor my extended warranty... surprise huh ??? anyway i talked to a factory rep. about the white vertical bar and he stated the unit has to come in..period. i said , so you know about this problem, he said yep, and the unit has to come in.. if your unit is under 2 years old they will warranty the repair, you have to pay the shipping to them, but they sent me a replacement unit next day air.. absolutely awesome customer service.. just google " optima projectors factory support" you will get an e-mail address. they e-mailed back immediately with a 800 number and we went from their..they were great and totally stood behind their product..
Seeing vertical lines on the picture
do the lines follow the same vertical pixel width from top to bottom or do they cross pixels? first try going into the menu and select auto-adjust. it just might be out of sync. you can adjust the resolution as well. if nothing changes, you might have a bad dmd (digital micromirror device). if that's the case and the projector is pretty old, replace the projector.
My Optoma HD 200x projector has developed constant evenly-spaced white vertical lines on the image at all times...if it is the motherboard, where can I get a replacement from?
I has his problem with hd200x. Out of warranty so i opened it up, pressed down on the metal plate above the motherboard (left hand side with lens facing away form you) and hey presto, problem solved. been running for hours since with no problems. Might be a loose connection from hanging from a ceiling mount im not sure but its fixed!
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
1helpful
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Help me please Optoma HD72 DLP
In the menu you can change the phase of the signal or the tracking. In Menu - Setup
1helpful
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
