Question about Kitchen Appliances - Others
I have 2 'Madonna and child' standard lamps, whose halogen bulbs have all blown. Replaced them carefully - not touching the bulbs, but NONE of the lights work. Any ideas please? Thanks!
  • 37 Answers
These could be low voltage lamps if so they have a transformer normally mounted in the base it sounds like this has blown not the lamps.
Another common cause is burning of the lamp holders especially if the lamps are wire ended..
HTH
Posted on Nov 14, 2009
My microwave keeps blowing the halogen lamp
thing to remember about all halogen lamps they are very perceptable to dammage done by forign contaminats on bulb ( finger prints are one of these ) causes hot spots to glass and weakens them allways use a clean soft dry cloth to handle them
Sep 09, 2014 | Microwave Ovens
Tip
Today's vehicles come equipped with halogen head lamp bulbs, they are brighter...
Today's vehicles come equipped with halogen head lamp bulbs, they are brighter and for the most part a lot easier to replace then the old style bulbs of years past.
When replacing any halogen type bulb please be careful not to allow your fingers to touch the glass on the bulb, your skins oils can shorten the bulb life by half being they develop high intense heat, which explains why they are so bright and excellent for night driving.
Also please use care when installing a light film of dielectric grease on the electrical connector plugs, don't get that grease on the bulb either, the dielectric grease keeps the connectors moisture and corrosion free for extended bulb life as well.
on Jun 06, 2010 | Hand Tools
Tip
Extend the life of your head liamps
When replacing any halogen type bulb please be careful not to allow your fingers to touch the glass on the bulb, your skins oils can shorten the bulb life by half being they develope high intense heat, which explains why they are so bright and excellant for night driving.
Also please use care when installing a light filmn of dilectric grease on the electrical connector plugs, don't get that grease on the bulb either, the dilectric grease keeps the connectors moisture and corrosion free for extended bulb life as well.
on Jun 05, 2010 | Toyota Camry Cars & Trucks
How do i fit a new headlight bulb on 1995 jeep cherokee
Check this details, from the Repair Manual...
HEADLAMP BULB REMOVAL
(1) Lift hood to access lamps.
(2) Reach into engine compartment and locate lock ring supporting the headlamp bulb assembly.
(3) Rotate the lock ring 1/8 turn counterclockwise (Fig. 5).
(4) Pull the bulb (9004) straight out from the housing. This is a halogen bulb, take care not to touch it with your fingers.
(5) Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Hope this helps.
Feb 27, 2013 | 1995 Jeep Grand Cherokee
Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
How to change a headlight lamp on a 2001 nissan maxima
1. Unplug electrical connector from headlight assembly by squeezing both sides and pulling.
2. Remove rubber hood
3. Undo metal clips and flip down
4. Insert new halogen bulbs, be careful not to touch the bulb glass.
Then, do it all back up!
Dec 07, 2009 | 2000 Nissan Maxima
WHAT IS THE BULB NUMBER FOR THE BRAKE LIGHT ON 2005 TRAILBLAZER
2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
Nov 19, 2009 | 2005 Chevrolet TrailBlazer
Need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
REPLACEMENT OF [LOW BEAM] HALOGEN BULB IN 2004 Buick LeSabre
I just Replaced a Low Beam Light bulb on a 2005 Buick La Sabre.
If You use a Metric socket and Remove the Two Silver bolts Attaching the headlight Assemble onto the metal surrounding the the lamp assembly it comes out to the front. This makes it much easier to access the bulb. Twist it counerclockwise & it comes out by pulling gently on the bulb. Then by realeasing a tab that is the socket holder bulb can be removed & replaced with a New #9006 low beam halogen light bulb. Wrap a Paper towel around the bulb & do NOT touch it with your bare hand as this wiil ruin a halogen bulb,
Jan 22, 2009 | 2004 Buick LeSabre
Kitchen Appliances - Others Logo
113 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
