Question about Seagate FreeAgent Go 120 GB USB 2.0 Hard Drive
I plug in my free agent go external hard drive to my pc but it wont even show that is connected in my drives... it works fine on my laptop all of the software is on the drive but I am unable to download it to my pc because it wont show up as even being connected it did work one time but never again... please help!!!
    President:
  • 2,030 Answers
Sounds like either a Bios problem, or just needs drivers installed in the non working problem.
You may have a USB conflict.
Try to remove some items in your hardware manager under windows, then let windows re ad them, that may fix your problem.
Posted on Nov 13, 2009
My computer wont detect my external
Hello Friend, after reading your problem i suggest you that first check your connection cable it may be corroded or stretched try new cable this may be solve your problem.
If still you got same problem then go to manufacturer for solving this because this may be internal problem like your hard drive lens is not working or the driver card may gone this is done sometime because of attaching or removing hard drive unsafely like just plug in and out do not use safety remove option. So go to manufacturer of hard drive if it is in warranty then they may repair or even replace it.
Hope this will solve your problem.Best of Luck...
Jul 07, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
HI! I just bought a free agent 1TB to USB 2.0.
I'm not familiar with Carbonite but can't see why you couldn't use it to backup your new drive provided your PC just sees out as an ordinary (if external) drive. As for USB compatibility, the USB specification is backward compatable so your drive should work fine, if slower, when connected to a USB 1.0 port.
Hope that helps.
Aug 13, 2017 | Seagate Free Agent Go Small 12 GB USB...
I have a problem with my seagate agent go 500 gb. when plugged in to my laptop it doesn't detect it and it freezes my laptop until i unplug it. how can i get to my files in the external hard drive?
try to connect it to other computer, if it doesn't help, hdd is probably broken. If you disassemble, you will find internal hard drive, which you can try to connect to desktop PC to save your data, or look up for some data recovery company
Jul 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Nov 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Nov 13, 2008 | Seagate Free Agent Go Small 12 GB USB...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Power problem
just reading this forum I think I have bought a total POS. Damn! wich i would have read this first. This boat anchor has all of my backup on it, is only a month old and is now junk. What is this the 3rd world's way of collecting all of our data when we return them?
Apr 27, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 120 GB USB 2.0 Hard Drive Logo
193 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
