The steps to change the audio language on a movie on your TV can vary depending on the TV and streaming service or media player you are using. Here are some general steps you can follow:
Navigate to the movie you want to watch and start playing it.
Look for the "Audio" or "Language" options on the playback screen or in the settings menu of your TV or media player.
Select the desired audio language (in this case, English) from the available options. Some streaming services may have a separate audio track labeled "English" or "Original Audio," while others may have language options in the settings menu.
If you do not see an option to change the audio language, try accessing the settings menu of your TV or media player and look for language settings. You may be able to change the default language of the device, which should also change the audio language of the movie.
If you are still having trouble changing the audio language, consult the user manual or help documentation for your TV or media player, or contact the manufacturer's customer support for assistance.
You may try downloading the VLC Player. It has built in codecs that can play almost all kinds of audio and video formats. It's also a free application. Just remember to open the file with VLC player for it to play.
Hi, You can download the latest version of Media Player Classic (K-Lite Codec) FOR FREE It will install all the required CODEC and you can play all audio - video files.
windows media players seem to have a prob. with having all the codec you might need to play a movie. ...even after you install more codec. ....go to the site for VLC media player and download it and you it as a default player. ....vlc media player has all the codec's in it that you would ever come accross. ....works great for me and has never found a movie it could not play
The mp4 files must be maximum 320x240 resolution, any larger and it will tell you that the file is not supported. If the mp4 is created with any profile other than "AVC Baseline" it will tell you the file is corrupted. It also won't do DRM, but I can't remember what, if any, DRM systems typically get used on mp4 files.
do you have video software installed ? Real Player, Jet Audio, Windows Media Player .......etc
make sure you have them and if you're trying to play a move, look at the extension ( Name.WMV) .WMV is for windows media video, which works on windows media player. you have to have the right program to play the video you want depending on the extension.
I have Jet Audio, its a very good program that can play many types of movies. you just go to preferences ---> file type associations ---> then check all and it will play almost any video or audio file you have. without needing to download all other software. One For All
There are literally hundreds of audio and video codecs out there, not to mention the dozens of possible media containers (file-formats) to hold and synchronize the audio and video streams in a movie.
1) The first step is to identify the codecs and container interfaces needed to play each file.
2) Download a copy of the G-SPOT codec information appliance from:
http://gspot.headbands.com/
3) Use this awesome tool to identify the codecs and container,
then download the correct codecs.
You can also test/play the movie from within GSPot.
4) Finally, keep in mind that media from P2P downloads is often corrupt (or worse) which may be the reason the audio does not work. The file type could also be mislabeled or have the wrong extension.
5) I recomend emule over lime wire, with an inter-connected VLC player. The VLC player is very good at playing incomplete or damaged movies and audio. (it is free)
6) Finally, when downloading movies, alway DL more than one version at the same time, hoping one will work.
prefer larger files for better quality, and avoid small files like the plague because the are often malware.
A movie should be at least 5 MB per minute. Anything smaller than that is highly suspect. most formats, except real-media.
