Rangemaster Kitchener 110 electric cooker. Right hand fan working and thermostat light comes on but no heat. It packed up half way through cooking. Any ideas please
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
The clock must be set to the time of day before the righthand oven will work. The manual can be found here: http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
