Question about Hitachi DZ-BX31E DVD Camcorder
Finalizing How do i finalize a disc so it will play on my dvd player?
Cam must be plugged into the mains adapter/charger to finalize a disc
1 - press the DISC NAVIGATION button
2 - press the MENU button
3 - use the froward/backwards/play-pause buttons to choose 'Finalize Disc' on the disc menu screen
Posted on Jun 18, 2008
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
I have recorded many DVD's with you Centrios EDW8020 it works great however I can not play them back on other DVD players. The disc may not been finalized to finalize them I can not acces Disc Utilities...
Hello Joe,
Most of these DVD recorders are really meant to be recorded and played basically on the same machine... Now if the DVD player (that you wish to play, is an older model that is the problem)
But, as far finalizing place the DVD unto tray... close it...now that menu (using the remote) press it..you should have a menu and top menu (top is settings) the menu is play dvd jump to next scene..in settings an Disc that is not finalized should be able to name it and customize it...note if you have use an DVD+/- R you must format prior to use (finalizing is on this same)
Nov 25, 2010 | Televison & Video
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
No finalizing dvd disc
Did you check to see whether the other player will play that type of disc?
Dec 10, 2008 | Sony Televison & Video
Finalizing
-R and +R auto-finalize, only +RW and -RW require manual finalization - if the option is no longer available, it is because the discs are already considered finalized by the player. If the disc edit option is greyed out, and you cannot play the discs in another player, then the recorder will need to be replaced b/c it is consistently producing bad recordings. Try unplugging and replugging the recorder once just to be sure it isn't a temporary problem.
May 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Aug 30, 2007 | Sony DCR-DVD301 DVD Camcorder
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Open Questions:
Hitachi DZ-BX31E DVD Camcorder Logo
369 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
